90* MAF rotation
Old Mar 9, 2008 | 08:18 PM
REVAK's Avatar
REVAK
Default 90* MAF rotation
Those of you who have done this , what are your observations and results ? Thanks in advance........
Old Mar 9, 2008 | 11:44 PM
edv2122's Avatar
edv2122
I have but I did it with the maf screeen removal and Vram so hard to say. Doesnt cost anything to try it.
Old Mar 10, 2008 | 02:46 AM
HuskerBullet's Avatar
HuskerBullet
I rotated my MAF 90 degrees with the screen removed and didn't notice any improvement, but it just makes sense to do it as the airflow detection sensor is now parallel with the throttle body butterfly....a little (probably imeasurable) more air flow.
Old Mar 10, 2008 | 10:16 AM
5 Liter Eater's Avatar
5 Liter Eater
St. Jude Donor '11
Clocking the MAF should only be necessary on a vehicle with a sharp bend in front of the MAF. We have a very straight shot. Even then you cannot just clock it ~45 degrees at a time until you feel a SOTP gain. You'd have to log the fuel trims or AFR error against the MAF transfer table to see where it follows the general polynomial curve best.
Old Mar 10, 2008 | 11:35 AM
Zig's Avatar
Zig
From: stafford country, va. Avatar: Me on turn 3 @ Bristol (The World's Fastest Half-Mile)
think of the whole system as a air tunnel.
imo, it's the easiest free mod. around, but then again...
without getting too philosophical, the more air you push through it (with it rotated) the better it will perform. the maf housing has an integrated airfoil. it's questionable if it provides any gains but imo, i prefer to align it with the tb butterfly post.
i believe rotating it only works on the '05-'07's. if i recall correctly, the '08 c6 uses the c6 z06 probe style maf.
Old Mar 10, 2008 | 11:36 AM
Zig's Avatar
Zig
Old Mar 10, 2008 | 12:06 PM
AndrewZPSU's Avatar
AndrewZPSU
The only way it will increase power is if it is reading less air and thus running the car leaner. If it is reading more air, its going to run richer.
It might be a free mod for un-tuned guys, but don't rotate it if your car is tuned.
Old Mar 10, 2008 | 12:53 PM
5 Liter Eater
St. Jude Donor '11
Turning it sideways is not going to increase airflow at all. Clocking the MAF is done to address airflow metering issues in abnormal air ducts.
you guys are taking snake oil to a whole new level. At least it's free snake oil.
Old Mar 10, 2008 | 03:04 PM
Just Enough's Avatar
Just Enough
I rotated mine 360 degrees and gained about 100 hp until my flux capacitor burned out.
All kidding aside, it makes sense to line up the MAF vanes with the throttle butterfly shaft, but the gains in flow and resulting hp would be hard to measure and probably harder to feel.
Old Mar 10, 2008 | 05:09 PM
davekp78's Avatar
davekp78
C1 of Year Finalist (stock) 2019
2016 C1 of the Year Finalist
2015 C2 of the Year Finalist
I have run the numbers, and if they are correct, there is turbulent flow, not laminar through the TB and MAF. Rotating the MAF won't make any difference.
Old Mar 10, 2008 | 05:16 PM
GMRULZ's Avatar
GMRULZ
I rotated my MAF 90 w/ the square portion of the sensor now pointing towards the hood. While I would think there is less "turbulence" (not additional air) by lining up the divider in the MAF w/ the divider in the TB, the big benifit in my opinion, is getting the built in IAT farther away from the hot upper radiator hose ie.. moving the square part w/ the connector farther away as it seems to be closest to the radiator hose. In addition I bought some rubber hot water pipe insulation and used it to cover the upper radiator hose below the MAF to reduce heat soak on the integral IAT. It is black and I secured it w/ black zippy ties. My hope is that on hot days the computer will not be pulling as much timing hurting my cars performance as it would have before the mod. We shall see.
Old Mar 11, 2008 | 05:24 AM
Zig's Avatar
Zig
Default an example
To 90* MAF rotation
