Which Radiator will work?
Old Mar 15, 2008 | 10:47 PM
RLSebring's Avatar
RLSebring
Supporting Vendor
From: Pensacola Florida GO GATORS!!! www.rlsebring.com www.c6c7vette.com
St. Jude Donor '17
Default Which Radiator will work?
I am needing a radiator for my C6 A6. Person has a radiator for sale from a Z-51 manual. Will this work in the auto? I checked on GM Parts House and the radiators they list are: W/out Oil Cooler Man or Auto, W/Oil Cooler list only one it doesn't say for man or auto. Any help is appreciated.
Old Mar 15, 2008 | 11:59 PM
Miaugi's Avatar
Miaugi
I would say it would work, but here are some things to note. For the pre '08 Z51 for a manual car it should have an engine oil cooler and a tranny cooler. In '08 the engine cooler was changed to an air cooler. For a Z51 car with an auto I think after '06 GM dropped the engine oil cooler but it still had a tranny cooler.
In any case it is easy to tell if you can get someone to actually look at the rad you are considering.
Old Mar 16, 2008 | 07:58 AM
RLSebring's Avatar
RLSebring
Supporting Vendor
St. Jude Donor '17
I have a '07 Z-51 that the transmission is for. Am I looking for the transmission line fitting on the passenger side of the radiator? If the rad does have the fitting for the oil cooler can I simply plug the fitting and not use them? Thanks for your help.
Robert
Old Mar 16, 2008 | 09:57 AM
Miaugi's Avatar
Miaugi
Robert
I installed a Z51 rad into my '06 F55 car to aid with engine oil cooling (EOC). The EOC is on the drivers side and on the pass side is the tranny cooler (TOC). I did not have a need for the TOC so I simply put some plastic plugs to cover the holes to keep dirt out and I guess you could do the same for the EOC holes.
The only think I am not certain of is the rating (capacity) of the manual TOC compared to a TOC designed for an auto car? I would have to think they are the same but I don't know for sure.
If you are getting a decent deal on the rad I would say do it and once installed and the car is on the road, just watch the tranny & water temps to see if they stay in the "normal" range. Worst case senario if they don't is you could add an air cooler, plumb the EOC into the circuit and run the tranny fluid through both or sell the rad and bite the bullet on the OEM correct rad or an aftermarket one.
Good luck with the project.
Old Mar 16, 2008 | 06:22 PM
RLSebring's Avatar
RLSebring
Supporting Vendor
St. Jude Donor '17
Thanks Guys for the information. It was a great help and we got it figured out.
Robert
Old Mar 17, 2008 | 04:50 PM
andreas g.'s Avatar
andreas g.
Since you need one why not get a direct fit dewits large cap. unit? I did when I put a 427 in my 05 Z51. It's a bolt in unit. Works great. Not much more than you're going to pay for a stock unit ( $600 )
Old Mar 17, 2008 | 08:01 PM
Mardis Gras's Avatar
Mardis Gras
I would check out either Dewits or Ron Davis Racing
Good luck on your project
Old Mar 17, 2008 | 09:28 PM
RLSebring's Avatar
RLSebring
Supporting Vendor
St. Jude Donor '17
For the project at hand I really didn't need anything more than a stocker and found one dirt cheap in almost new condition. If in the future my 427 project bears fruit I will indeed go with Dewitt's. I seen and talked with their rep at the Orlando Corvette show in January and that is a sweet rad.
Thanks again for all the input.
To Which Radiator will work?
