Which spring is softer?
Old Mar 18, 2008 | 10:18 PM
chazc6's Avatar
chazc6
St. Jude Donor '10
Default Spring rate
Originally Posted by glenB
In days past it was determined by engine/suspension/options/
To be exact you would need to contact a Chebby dealer.
My best guess would be a manual with 1LT option as the softest spring.
Hello
I replaced my stock springs over the winter with C6 soft ride M6 springs, an i'm trying to figure out if i chose the softes spring option, It seems to be a softer ride, but not a significant difference, I can't tell if it launches better until i get to the track. If i don't have the softest springs i will replace them again.
Old Mar 19, 2008 | 01:03 AM
User 81424's Avatar
User 81424
Originally Posted by chazc6
Do you know if the C6 T1 is the manual trans base model?
Is the C6 base model with the 420 rate a auto trans?
T1 is a class of racing in the SCCA, it is a kit you can buy from GM.
Old Mar 19, 2008 | 06:58 AM
glenB's Avatar
glenB
St. Jude Donor '08-'09 & '12, '14
Hello
The Z51 has slightly less PSI in the rear than the base, according to the chart.
If drag rracing is your goal, I would get all three springs and try each. Get the stiffest sway bar for the rear and a set of QA1 adjustable shocks. The vette already has a problem with anti squat.
