I won a tune!
Money goes to St. Judes so everyone wins here!!!
Although most tuners just tune for a canned AFR regardless.
The exception to this rule is the mustang dyno which actually puts your car under load.
Chuck tuned my car on the street, then we put it on a dyno just to see if we missed anything, Chuck couldnt squeeze another pony out out on a dyno
You got a great tune DVL, but you needed to rent the dyno to verify. Another way of looking at it was that your tuner didn't have the capability to get more since he isn't as familiar with using dyno's. Just playing DVL's advocate (pun intended), not trying to knock Chuck at all. Another way to look at this is that not all tuners may be as good to just do a street tune. You can't say a street tune is the best without knowing the tuner, the conditions, and how the car is expected to be used.
As for what is the best tune, a fully loaded dyno that can hold the car in any RPM range under any load condition for indefinate period of time, followed by a street tune for verification.
If I had to choose one though, standard dyno or street......I would go street for a daily driver car.
However if you are one of those dyno queens which all they care about is HP numbers, then you need the dyno
Let me give you a better one.
My first car was street tuned. It worked great. One day I decided to do a top speed run. Somewhere around 7,700RPMs in 5th gear the engine experienced detonation and was completely trashed.
Why? Because there is no way in hell a tuner could have experienced that kind of a load on the street during tuning. Street tunes are done in maybe 3rd or 4rth gear for a relatively narrow range of loads; you tune on a level road, then try to go WOT up a hill and now your car is experiencing a level of load that it did not during the tune.
A roller dyno is a similarly poor tuning device. An eddy current brake dyno on the other hand can go through every single possible load/rpm combo and will give you a much more thorough tune.
Ultimately your tune is only as good as the tuner who programmed it. That said though, an eddy current brake dyno is a much better tuning tool than a few pulls at one or two gears in a level road.
Let Charlie do his magic on his load bearing dyno and you will not be dissatisfied I'm sure. I don't care who is tuning the car, there is NO WAY you can ever hold the car in every load cell, under perfect conditions, and get 100% peak HP from every cell like you can on the proper dyno.
Everyone goes right for the top end numbers to see if your tune is on, but the major gains will be in the mid range and timing maps, those who say otherwise most likely do not own a dyno......
Serioulsy you think someone i going to run your car in 5th gear on a dyno at 7700rpms? Not to mention you do realize that it uses the same lookup table in 5th gear, that it does in 2nd gear, which you can hit on the street?
Most shops around here do not have load bearing dynos, maybe its different where you live.
Search my username for the thread.BTW you realize that the ONLY way you can get something even remotely resembling a real tune via datalogging in the street is to commit several FELONIES, right (at least here in CA anything over 100mph is a felony)?
For us having Load Bearing Dynos - well you all know ECS has the best equipment available
If you want proof of that try to hold a car at specfic rpm for 30 mins on the street - impossible.If there is not load bearing dyno than a combination of Street and Dyno tune would be the next best.
After that IMHO I would say Street Tune, then Dyno tune, then mail order tune. I put dyno before mail order because the people doing the dyno tune are doing it for your specific car. A mail order tune is generic by nature. Sure we can custom do a tune based on your mods, but it is based off experience of tuning and not car specific.
BTW - to the OP you are in good hands with Charlie. Very knowledgeable tuner.
Congrats
Actually Chuck and Devil went to ICS and i believe that they are pretty familiar with their own dyno. Chuck had used their dyno numerous times and i am sure that what the Devil said (
) is accurate because it was also confirmed by the dyno operator from ICS.
). The owner of the car is present at the time of tuning and this procedure is a "collaboration" between Chuck and the driver therefore he is able to custom tailor the tune to the driver specific wants, also, what is being discussed is what the customer expects form the car and how he is planing to use it.
Now since we kind of hijacked this poor man's thread with our debate :o
all i have left to add is that i see more and more people, slowly moving away from the absolute and definitive firm belivers of the "dyno is better that street" attitude (some of you are on this thread) and start thinking about the car's main application which is, to be driven on the street and not dyno, and, tune accordingly.
In the end, whether you go to the track, or you drive on the street, dyno tuning will always and forever be a simulation at best and nothing more.
FireEyes
) is accurate because it was also confirmed by the dyno operator from ICS.Actually i have to disagree, no disrespect, Chuck CoW is really that good as a tuner, keep in mind that i see his tuning results and people's reaction to these results every day ( no exaggeration) oh and C6Devil does know who the tuner is (just jk
No comment here but a question: at what point, in every day, weekend or sunny day driving, is the car being kept at the same RPM range for an indefinite amount of time (other than probably being stuck in bumper to bumper traffic)?
Good choice
FireEyes
That's easy: The answer to that is because anyone with $500 can buy HP Tuners and become a "Street Tuner", whereas to run a professional tuning shop with an eddy current brake dyno you need to spend around $100,000 on the dyno and pay all the bills associated with running a shop.
Once again:
To get anything resembling a proper datalog on the street you will need to commit several felonies. A full throttle run through 4rth gear will yield a fair amount of useful data but also put you at a speed where you are going straight to jail if caught. A few runs below the speed limit will yield very little useful data for tuning.
No street log can adress all possible load points. A brake dyno can.
I have no doubt that some tuners can do an incredible job on the street, but it is dangerous, illegal, and uncessary, and I would still expect that those tuners could do an even more thorough job if they used a brake dyno and then checked the tune on the street.
FireEyes
