MGW Shifter Shaft Replacement
Old Mar 20, 2008 | 10:53 AM
JSibert's Avatar
JSibert
Default MGW Shifter Shaft Replacement
Anyone else receive the care package form George? Yesterday I recieved a package with a replacement shaft in it. I have not called George to see what is going on, but I will. I sure hate tearing into the console again and getting the damn switch connections undone. A real pain in the ****.
Old Mar 20, 2008 | 11:39 AM
Jim Nebraska's Avatar
Jim Nebraska
I got my 25% OEM **** compatible shifter from MGW in Feb. I did receive an adapter to lower the shift height, but that also occurred back in Feb. I have not received anything more recently.
Old Mar 20, 2008 | 12:00 PM
MGW George's Avatar
0MGW George
Former Vendor
St. Jude Donor '08-'11
read the enclosed document and you will see why it was sent out. there are some pretty siginificant upgrades to the shaft and the material on the pivot ball has been changed to a high temp poly blend made up for us by dupont.
i know it is a pain but you REALLY should replace the shaft as soon as you can. the poly ball in the current shafts should be fine but we have had a few instances where high heat has cuased them to slip on the shaft. hence the new design.
also we have altered the center shaft design to actually allow the dust boot to snap into a groove LOWER on the shaft which allows the oem rigid inner boot to sit a bit better and really seals the tunnel from cabin noise.
regards
george
Old Mar 20, 2008 | 12:14 PM
johnodrake's Avatar
johnodrake
Moderator
regards
george
George,
Which customers are getting them?
JD
Old Mar 20, 2008 | 12:23 PM
BearZ06's Avatar
BearZ06
St. Jude Donor '09 thru '17,'22 thru '26
If you are careful it can be done without disconnecting wires. I did my reinstall this way. Another tip is to tape the front of the ash tray door with painters tape to hold it closed. Mine came open when bumped which put the top on the bottom I didn't notice it and got some minor scratches on the door from the shifter shaft.
Old Mar 20, 2008 | 12:25 PM
MGW George's Avatar
0MGW George
Former Vendor
Originally Posted by johnodrake
George,
JD
only those that have the pivot ball design not the pivot CUP design need them but if anybody wants the new design shaft they can call julie or peggy and we will be happy to send you one.
regards
george
Old Mar 20, 2008 | 03:01 PM
kbobk's Avatar
kbobk
George,
How do I know which one I have? I received my shifter in late January. Also, I had e-mailed you in mid/late-February asking for one of the new machined cups for the pivot point and you said you were sending one out, but I have never received it.
Thanks.
Old Mar 20, 2008 | 03:11 PM
MGW George's Avatar
0MGW George
Former Vendor
Originally Posted by kbobk
George,
Thanks.
i would just give julie a call and ask her to send you one of the new shafts. that way you have the latest version.
regards
george
Old Mar 20, 2008 | 03:18 PM
SpinMonster's Avatar
SpinMonster
George, what is the thread size for the shaft going into the 2 different bases for the stock shifter ****?
Old Mar 20, 2008 | 03:26 PM
MGW George's Avatar
0MGW George
Former Vendor
m12 x 1.75 metric
george
Old Mar 20, 2008 | 03:28 PM
SpinMonster
m12 x 1.75 metric
george
Thanks for the quick answer and by the way.....I'm loving this shifter.
Old Mar 20, 2008 | 03:47 PM
miami08VETTE's Avatar
miami08VETTE
regards
george
George I bought mine in late January. I later recieved the redesigned pivot cup for it. Which version does that make mine? Is my version fine or should I or will I be recieving a replacement shaft?
By the way George, this is one outstanding piece of customer service you have going on here! You deserve some type of industry award. Thanks.
Old Mar 20, 2008 | 04:31 PM
TCW's Avatar
TCW
St. Jude Donor '06-13,'16-'17, '19
I've NEVER been treated so well after the sale.
Tom
Old Mar 20, 2008 | 05:17 PM
johnodrake's Avatar
johnodrake
Moderator
regards
george
I'll keep that in mind, but I am happy with my shaft as it is.
Old Mar 20, 2008 | 05:57 PM
Beer Kahuna's Avatar
Beer Kahuna
Default This explains the UPS shipping notice I got today.
I was a little perplexed when I received a UPS shipping notification today from MGW. This must explain it - no real problems w/ mine except a slight buzzing from the stock **** on HARD accelleration. I won't receive my new piece until 3/27 but when I do, I'll install it and see how it goes.
Old Mar 20, 2008 | 05:58 PM
Outsource's Avatar
Outsource
Default Thanks MGW
I was thinking to myself "hey, I got one of the new ones, and I havent received anything in the mail".
And then.........BAMM!!
........got home and my new shaft was in the mailbox!!
Great customer service
Old Mar 20, 2008 | 06:27 PM
deanm11's Avatar
deanm11
I just received my shifter; was shipped out by you guys on Tuesday. I presume we all have the new design ? Thanks, really looking forward to experiencing your great unit.
To MGW Shifter Shaft Replacement
Old Mar 20, 2008 | 09:14 PM
NIGHTSTALKER's Avatar
NIGHTSTALKER
I pull the console to the passenger side with the wires in place without any issues.
Old Mar 21, 2008 | 10:06 AM
JSibert's Avatar
JSibert
You must have longer wires to the switches than on mine. I do have to remove the auxillary plug connection and the Active Handling connection or it is going nowhere. It will only move about two inches with those two attached. The Lighter plug connection is also a very short wire that only allows very little movement. You are lucky to have the luxury of longer wires.
Old Mar 21, 2008 | 10:23 AM
edv2122's Avatar
edv2122
I can and have removed the center console without unplugging any of the wires. Made the removal and install much easier.
