toyo r888
Old Aug 14, 2008 | 08:19 PM
  #41
LS3FORME's Avatar
LS3FORME
fast lap time = sticky tires
sticky tires = lost of $
hence $= fast lap time
Old Aug 15, 2008 | 06:24 PM
  #42
TTRotary's Avatar
TTRotary
Originally Posted by tmak26b
The Toyo tires are certainly good tires, but it's not going to be a great choice for the original poster.
Then please help us all and suggest a superior street tire for the OP.
Old Aug 16, 2008 | 02:09 AM
  #43
tmak26b's Avatar
tmak26b
Toyo R888 is not a good drag tire, all he will do is hop the rear wheels and break axle. He is not looking for a strict street tires, he just wants something he can use for both applications
Old Aug 16, 2008 | 07:37 AM
  #44
NOSLO6's Avatar
NOSLO6
Depending on his power level they may hook fine. R-compound DOT's all but cured wheel hop in both my vettes.
But OP, if you're really thinking of serious drag racing and want 60's-- I'd go 18s at all 4 corners and use the MT Street Radial. I've cut 1.4x 60's on these tires on the GN with no problem. Note though, that there's no perfect tire for a combination street / race vehicle and here you'd be trading off handling and tread life for stick that doesn't quit.
Old Aug 16, 2008 | 05:36 PM
  #45
TTRotary's Avatar
TTRotary
Well I have this tire, and I have zero axle hop. On the other hand , I did have axle hop with the F1s, and that was even with Bilstein shocks. This is on the street of course. There are no guarantees at the strip, regardless of what tire you run. Guys have fragged diffs 1 foot off the line with drag slicks and stock power, and at the opposite end you have Ranger with probably 100 passes on EMTs and never a broken diff.
I'm not trying to bust your chops, but you keep advising against the R888, yet you offer no alternative. I'm pretty sure that is not a solution for him. The R888 is not the best race tire (grip), drag tire (sidewall flex), or street tire (longevity), but it way stickier than a street tire, comes close to a race tire in grip, and is drivable on the street for extended periods. Everyone who actually has these tires says the same thing. So again, if you have a suitable sticky street tire in mind that is superior to the R888 that you actually have experience with, we'd like to hear what it is.
