Need some help guys, just put on new KDW2s today & I must say I'm very impressed. Now I need some helps for alignment specs up front for a Z51 that has been lowered all the way on stock bolts. Rears all the way + cut 1/3 of rubber bushing off (don't know if that matters or not).We were supposed to do the tires & alignment today, but tech said he only had stock specs. The cords on the front tires were showing on both tires inside edge w/ 14K miles. Need advise please.
Given answers, I'm not clear. If stock specs were good, what accounted for the front tires wearing to the cord on inside edges of both, rear did wear evenly. I guess the better question is, now that new tires are on, what is the spec to use to avoid repeat wear up front? Thanks for your help.
Mike,
The stock specs are good.
You lowered your car and that changed the alignment which caused the front tire wear.
I would use the stock specs for your car and stay near the middle of the range (preffered settings). If your alignment guy doesn't understand that then go elsewhere.
I and many others here keep telling those who lower their car to have the alignment CHECKED. You are proof why.
