Paddle shift will not engage
Old Mar 28, 2008 | 11:18 PM
Crystal Vette's Avatar
Crystal Vette
Default Paddle shift will not engage
I have a 2008 C6 coupe auto with paddle shift. Has been perfect until and could use some forum help.
I put it is S mode and the paddle shift is not available. Nothing displayed on the HUD. Can't shift up or down. Vette still moves as if it were in full auto mode. D or S no different. full auto only.... no paddle shift when moving shift lever to S. Paddles move but nothing is happening. Car is not stranded. Still drives ok in full auto. No codes thrown as no engine light and also called On Star and nothing they could diagnose.
Before I take it into the dealer I hope I can have some idea what might be wrong.
Need you help.
AL
Old Mar 28, 2008 | 11:46 PM
Vette_DD's Avatar
Vette_DD
If you've got it well down into "S" mode and you've hit the paddles, the gear you're in should show up in the hud. I'd say you've got no choice but take it to the dealer. Hopefully, it'll be something minor they can find and correct. Don't have any other suggestions.
Old Mar 29, 2008 | 12:07 AM
Bob06COUPE's Avatar
Bob06COUPE
Default ground cable
you might try disconnecting the battery ground cable at the battery for a minute. Just note you may lose your radio presets and you might have to re-index your windows(easy).
Old Mar 29, 2008 | 12:11 AM
Crystal Vette
I have dealer paranoia. I know....looks like I will have to bring it in.
To Paddle shift will not engage
