Rear Tire Question?
It would be great if they would make a 315/30-19 as it would be even closer (26.4").
You can try a 325/20-19, but you are limited to the Goodyear or Bridgestone runflats and it is difficult to fit inside the fender.
Double-check the data sheets for particular tires. I have a PS2 data sheet here that specifies for the 255/35-18s a minimum 8.5 inch wheel and for the 295/30-19 size a 10 inch, so the stock wheels would be just in the range for those.
The main thing is to keep the front to rear ratio close to avoid confusing the active handling. I've heard 3% quoted as the limit, but I'm not sure if that's right or not, and I'd try to stay as close to the original ratio as possible.
This will affect your speedometer a bit, but that's easy enough to fix. Also, it will lowers your car by half an inch, and will increase the gap above the wheels by a similar amount.
Of course, if low is what you're going for you can eliminate that gap by lowering the car another half inch, which should be within the range of the factory adjusters.
