Tire psi sensor canister
Old Mar 31, 2008 | 10:53 PM
Stage IT's Avatar
Stage IT
Default Tire psi sensor canister
Hey guys I have a CCW drag pack coming and will switch wheels often so i'm planning on making some type of canister to hold tire psi sensors and place it in one of the rear cargo compartments does anyone have any suggestions or a setup that has been used?
Old Mar 31, 2008 | 11:25 PM
ben dover's Avatar
ben dover
From: When all is said and done... there is a hell of a lot more said than done. Riverside,Texas
St. Jude Donor '05 thru '26
There was a thread on this some time back. I believe the guy used some 4" sch. 40 PVC with 1 glue on cap on one end and a threaded adapter plug on the other end with a schrader valve in the cap and the sensors inside. At least that's what I'd try.
Old Mar 31, 2008 | 11:30 PM
1bdasvt's Avatar
1bdasvt
St. Jude Donor '06-'09
I just bought some CCW 18" wheels that I'll be using for the drags,but I bought an extra set of TPMS and will "re-learn" each time I switch wheels.
Won't that work the same for You?
George
Old Apr 1, 2008 | 12:51 PM
Stage IT's Avatar
Stage IT
George
I'd just like to never have to worry about them again
Old Apr 1, 2008 | 05:46 PM
Stage IT's Avatar
Stage IT
any pics of these canister setups ....dennis maybe?
Old Apr 2, 2008 | 12:22 AM
kelp's Avatar
kelp
That was probably me.
Here's what you do. Use the TPIS sensors already setup with the car. At a tire store have them pop open the tire and remove the sensors. Get a short section of 4" pvc pipe and two end caps. Securely glue one end on the pipe. I put three TPS sensors in a plastic bag and put them inside. I drilled the other cap so that I could use one TPS sensor to pressurize the container. Glue the cap on and purge it a few times to get rid of the toxic glue fumes. I store it in the trunk.
It has worked continuously since I made it.
Old Apr 2, 2008 | 01:07 AM
siffert's Avatar
siffert
George
The only problem with that if and when you drop the tire pressures below 24psi...the sensors will pick up on that and at the minimum you get DIC error messages. At worst it may go into limp mode. The sensors in the cannister fools the computer into thinking the DR's got 30psi when in reality the DR's (that have no sensors) have 18psi.
Old Apr 2, 2008 | 09:29 AM
06C6FVR's Avatar
06C6FVR
You dont need them for the dragstrip. The car will just show service traction control, but wont affect performance. I have done this MANY times with no ill effects. If your tire sizes are different, you will have to turn traction control off, but no limp mode ever for me. IMHO a waste of time , $$ and effort to worry about putting sensors in the rear of the car.
Old Apr 2, 2008 | 11:09 PM
kelp's Avatar
kelp
Agreed. Unfortunately there are 3 or 4 permutations of this TPM system I have read about so far. It is evidenced by the same year/model cars behaving differently. In the end analysis, the owner has to do what works for him with his particular system. The only common element amongst them is frustration.
Old Apr 2, 2008 | 11:42 PM
siffert's Avatar
siffert
???????? You may not need them, but pray tell, how do you know 100% that other folks wont need them? The only way I see that one 100% wont need them at the strip is if you bring your oem tires w/ sensors at the track along with your DR's. For you see, the car signals the sensors once per hour to see if they are there and working OK. I got limp mode before with no sensors and have no intention of my car going into limp mode on the track.
Old Apr 3, 2008 | 07:54 AM
dennis50nj's Avatar
dennis50nj
on my year 05 a4 i had the problem, xx xx and limp mode, so i put the sensors in my drs, then i got trans output sensor no reading from low tire pressure, limp mode. so the only answer was canister
Old Apr 4, 2008 | 05:33 AM
06C6FVR's Avatar
06C6FVR
Sorry, but i have had 2 different c6's (06 Z51 and 07 base) and neither one gave me any problems. Not sure why anyone else is having probs...but I have also talked to other C6 guys at the track, and they had no problems either. I dont doubt that some of you have had some problems...maybe its an 05 deal...really dont know, but neither of my cars had ANY issues whatsoever with leaving the stockers at home...
I have also driven several hours on the DR's on the street, turned the car off and on several times and never had any problems...just leave the traction control off and it has never given limp mode to me... do you really need traction control if you arent driving aggressively? No, 90% of the cars on the road dont have it anyway.
Old Apr 5, 2008 | 12:04 AM
kelp's Avatar
kelp
See my post #9. Systems vary.
Old Apr 5, 2008 | 03:39 AM
06C6FVR's Avatar
06C6FVR
I wasnt aware of that...thanks for clarifying. Just seemed odd to me that 2 different cars of mine (different years even) behaved Exactly the same with no ill effect. I will never claim to be the end all answer, just based on my personal experiences! With time, we all have wisdom!! If it werent for the forum, i wouldnt know anything about the car I drive, but i believe that we never stop learning!
on another note, just got my 3.90 gears today, and drove around on my brand new drag radials to break them in, and was away from the sensors for over 4 hours ,with 2 starts in between, and still go Zero errors, no limp mode...only traction control kicked in because of the shorter tires (turned off the TC, and immediately drove perfect).
Thanks for the good info!
Daren
Old Apr 5, 2008 | 07:34 AM
siffert's Avatar
siffert
"Traction Control Kicked In" = what you got was the "Active Handling" enabled message. This will put you into limp mode at speed over 55 mph or WOT. Yes, turning off TC (by hitting the button) in this circumstance will disable that "Active Handling" message but one cannot say for 100% certainy that it is in fact been 100% fully disabled in this circumstance. I am not going to chance that effecting on my ET at the strip, ergo my cannister.
Old Apr 5, 2008 | 07:52 AM
dennis50nj's Avatar
dennis50nj
i feel the best way is ah&tc off and you cant really get limp mode until you start getting great 60 fts i drove and started car 100 times over a couple month period and drove hundreds of miles. no xx xx 0r limp mode, but the first time i jumped on it hard all bets off
Old Apr 5, 2008 | 10:48 AM
06C6FVR's Avatar
06C6FVR
Actually, no it wasnt an active handling message, it specifically said traction control active, not active handling...I usually turn the TC and active handling off 1st thing, i just forgot on the way home.
And I did several pretty hard runs dennis, and still no probs.
But hey, each car could be different like someone else said. No big deal to me!
To Tire psi sensor canister
Old Apr 5, 2008 | 03:14 PM
dennis50nj's Avatar
dennis50nj
i believe that daren every circumstance is diferent
Old Apr 5, 2008 | 04:52 PM
06C6FVR's Avatar
06C6FVR
You are probably 100% correct. !
I guess im just glad i dont have to worry about a canister!!
Daren
Old Apr 19, 2008 | 03:31 PM
Stage IT's Avatar
Stage IT
Hey guys my canister is finished and in the car for about a week now and every so often i'll get a service tire moniter on the dic and the XX XX but it will go back after a will to being fine. Canister in located in the rear pass compartment. Has anyone else had this issue.
