What should you expect...a code being thrown. A tune will help tons and get rid of the majority of torque management.It'll really wake the car up and you won't have to worry about CELs illuminating, burning into your forehead like Terry Bradshaw.
What trips the code? The CAI or the headers and why?
Chevy uses a dual O2 sensor system on each side to test the Cats. The front O2 sensor inputs AFR changes and the rear should be flat as the CATS burn any excess fuel. However, for the Cats to light off, they must reach a very high temperature. You will recall that C4 vettes have a single Cat that is halfway down the exhaust pipe and only one O2 sensor, whereas C6 cars have the Cats up front bolted directly to the cast iron exhaust manifolds. This is so they heat up almost immediately after startup.
Now, you install long tube headers and a hi-flow X pipe and the Cats are down wind a lot further and it takes them longer to fire up. The second O2 sensor output is not flat when this happens and this sets a P0430 or P0420 code meaning the Cats are not working. The car will still run fine, you will just be staring at the check engine light periodically.
Most tuners can tune out the rear O2 sensor or supress the Cat codes. You can also do this yourself with a hand held Predator.
Nice clear explanation ... thanks! So, does the code go away when they do reach temp? Or does it remain until it cycles so many times? I take it that also clarifies that it is the headers that result in a code and not the CAI?
This is important but could anyone shed any light on performance?
I'd like to know more about this too.Those of us that want to retain our warranties but still be able to do some mods without tuning. What can we do without having a CEL on all the time?
Putting headers on will void the warranty as well, so you might as well get a tune.
Taz1613
Actually, they will only void the warranty if they can prove that the part caused the failure. The only thing it WILL void for sure will be your cats/exhaust/mufflers.
Federal law sets forth requirements for warranties and contains a number of provisions to prevent vehicle manufacturers, dealers and others from unjustly denying warranty coverage. With regard to aftermarket parts, the spirit of the law is that warranty coverage cannot be denied simply because such parts are present on the vehicle, or have been used (see Attachment A).The warranty coverage can be denied only if the aftermarket part caused the malfunction or damage for which warranty coverage is sought. Disputes in this area usually boil down to arguments over facts and technical opinions, rather than arguments over interpretations of the law.
It's hard to say how much you're leaving on the table. I have seen bone stock '08's that are ~10.5:1 AFR on the dyno so right there you're leaving a lot on the table. Hard to say what the CAI and exhaust mods will do to the motor without tuning/logging it.
You may or may not throw a code with the headers and CAI.
I picked up 18 rwhp with a tune. Why spend 2k on exhaust/headers/intake and then worry about $500 for a tune. Just keep writing the checks and it will go faster Oh yeah and get a 160 stat to go with it.
For what it is worth, my LS2 M6 with a callaway intake, headers, 160 stat, exhaust made 393rwhp on the valvoline mobile dyno at the NHRA races last week. That is a solid 40-50rwhp over a stock LS2 M6
Taz1613
Actually I talked to the service manager and he pretty much said what the poster above stated. Only thing headers would affect is warranty on your exhaust, cats, rattles. It's not the cost of the tune, I just don't care to lose my warranty on my 08 because of a tune. Yet I'd still like to add CAI and headers and maybe porting. I guess nobody has done this before since the tune issue really wasn't a concern before now.
Is the computer not "smart" enough or self adjustable enough to learn and adjust fuel mixture over a period of time?
In other words, without touching the factory OE ecm calibrations, wouldn't the ecm learn and adjust a/f ratio properly over a period of time...just as it would properly adjust itself when the car is driven in the mountains at 13,000 ft and adjust itself properly back down at sea level, and vice vera?
When my C6 was delivered, within 3 months I installed DynaTech coated headers, cats, and x-pipe, along with a VaraRam. The car threw a code within the first 50 miles. I reset the code, and it never returned. My theory is that the ECM is designed to run the engine in varied enviroments. Below sea level in Death Valley to altitudes as high as 12,000 ft, and temps that vary as much as 150 degrees. I think it will, over a short period of time, compensate for the increade in flow and air fuel requirements resulting from the installation of the headers and CAI. Granted, a tune may give you a few more horses, but, IMO, it's not completely necessary. My car ran fine with the stock tune.
The most significant downside to not getting a tune after installing headers and a CAI is the lack of horsepower and torque you'll have after installing those mods - especially with long tube headers. The deletion of codes, CEL, etc. are all important, but you're doing it for power. Here's an example: I installed LG performance headers and gained only 7 hp without a tune. I gained 28 hp and lots of torque with a tune. Your car will run fine without a tune for daily driving, but you won't realize the cost/benefit of the upgrades.
No. The PCM looks at the injector flow table, MAF flow table and PE (power enrich) table to determine WOT fueling. It ignores the oxygen sensors. The only "learning" it does is if your setup is running lean in closed loop (cruising, part throttle) it will add fuel via positive fuel trims. If you have positive fuel trims because the PCM is having to add more fuel than the table say to then it adds fuel above what the tables say to in WOT. It does not work the other way around though. If the car is too rich and the PCM is having to take fuel out (negative fuel trims) it will not subtract fuel in open loop (WOT) for fear of creating a lean condition.
The LS3s will remove fuel. In stock form it would remove 9% on mine... I think its something to do with the new OS and getting ready to become a flex fuel vehicle... Infact the LS3 loves putting LTFTs on the WOT (which is unlike the LS2), but as 5 Liter Eater said, it doesn't generate them at WOT.
So when I tuned mine the first time for a 12.4 AFR, then drove around, suddenly that AFR became 13.2+....
Reason: little more detail...
Some great responses guys ... thanks very much. The issue isn't cost at all. I was considering the loss of power train warranty with a tune. I'm also not concerned about losing warranty for issues directly related to the headers or CAI. I think GM will use the position of a tampered ECM to void almost anything and everything. On the other hand, short of a catastrophic failure of the engine, tansmission or rearend, I wouldn't let a dealer touch my car anyway.
Also, as long as the tuner keeps your stock tune, you can reflash it back to stock and they will never know it was there.
