I have a 2006 convertible with 14,000 miles on the clock. Most of the mileage is non agressive at 40 mph. The tires are OEM Gy Eagle F1 Gs-2 EMT. Tire presure has been always maintained at 30 psi cold. The wheel alignment was set to the following shortly after taking delivery.
Camber Caster Total Toe
Frt. Spec -0.45 deg. 7.9 deg. 0.10 deg.
+/- 0.5 deg +/- 0.6 deg. +/- 0.2 deg.
The rate of front tire wear is a little more than double that of the rear tires and will be at 2/32" depth by 23,000 miles.
My questions are:
1. Is this normal tire wear for the C6?
2. If not, what have some of you done to reduce tire wear? i.e.
alignment changes, tire brand changes, etc.?
I would appreciate reading any comments to this post.
The longest mileage for your tires will be at a camber of -0.1 f/r that gives more tire to be "flat" but it reduces the response in the twisties. If you want maximum response in the twisties then set camber to -0.45 f/r (Stock). I'm at -0.1 for the maximum mileage for the tires. Handling is fine for a daily driver. Were I to desire to do autocross then I'd bump up the camber. I have near 11K in 14 months tires look great.
What pressure are you running? Are the tires wearing faster in the center of the tread?
I run 31 PSI in the tires and the wear is even as can be for all 4 tires. The camber will cause the inside edge of the tire to wear out faster than the middle or outer edge. There were pictures on here of threadbare tires on the inside and not even down to the warning bars on the outside tread. I had the camber dropped immediately on the car to try and extend the mileage on the tires.
To Modshack, eboggs jkvl and dave pawlowski thanks for your prompt and informative replies. My problem seems to be too much negative camber. I shall get it into the shop tomorrow. Again many thanks.
Elmer
My alignment is set like yours. But the center of the treads are wearing faster. Do you measure your tread depth or just eyeball it? I started off running 30 psi cold but after noting the center wear I have reduced the cold pressure slightly. (28 or 29 cold- depending on the season) But they are still wearing in the center faster than the edges. (slightly more than 1/32" difference) I have seen where someone here claims that reducing the pressure will INCREASE wear in the center on runflats but this just seems so counterintuitive to me. I did prematurely wear out the center of the tread on a pair of low profile performance tires on my SO's Mazda 3 by overinflation so I think my intuition is correct. Any ideas?
Darn tread looks so good I haven't even bothered to measure it. I'll give it a look and get back to you.
Flat as an aircraft carrier's deck. I don't have a gauge to measure it but I used a finishing nail and put a piece of masking tape on it to "spot" the depth and it was almost spot on all the way across the front and rear tires.
Elmer
Reason: Added tire check data
