Running Race Fuel?
Old Apr 7, 2008 | 12:33 PM
xkilo16x's Avatar
xkilo16x
Default Running Race Fuel?
Will running race fuel such as 100 to 110 octane do any good for running at the track?
I'm not stock, but I don't really have a tune. Only one for the TM and fan controls.
Old Apr 7, 2008 | 01:33 PM
k0bun's Avatar
k0bun
From: NJ..."the way I saw it, everyone takes a beating sometimes."
Without a tune to optimize timing, A/F, etc. the higher octane will do nothing for performance, assuming your car is running correctly. In all actuallity it may hinder your performance.
Old Apr 7, 2008 | 01:44 PM
SoldSyclone's Avatar
SoldSyclone
If you are knocking you can add just enough 100 unleaded the get to zero KR
If you are not knocking it will slow you down and waste your money?
What track? road corse or dragstip? temps?
If you are beating on the car in high temps on the roadcorse 95 octane may help.
Old Apr 7, 2008 | 03:00 PM
xkilo16x's Avatar
xkilo16x
Drag strip. Temps are around 45-50* F. DA is at 86 feet.
I'm not sure if I'm knocking or not. I usually run 93 octane. I'm just wondering if it would help.
Old Apr 7, 2008 | 03:54 PM
ronsc1985's Avatar
ronsc1985
Using higher octane than the engine requires does nothing for you but lighten your wallet which may cut your E.T. a little if you drive with your wallet in the car. The improvement will be several places past the least significant digit on your time slip unless you get change when you buy the gas. In that case you may slower if your change has more mass then the original payment
Until you reach the operating conditions, which for whatever reason, your car starts pulling timing the slower burn rate does you no good. Unless you car has some internal or electrical problem you will just be wasting money especially at the ambient temperature you stated.
Old Apr 7, 2008 | 04:24 PM
xkilo16x's Avatar
xkilo16x
Damn,
Thanks guys for letting me know in advance.
To Running Race Fuel?
