Lost active handling, telescopic steering
Old May 5, 2010 | 05:35 PM
drew47000000's Avatar
drew47000000
Default b
bump
Old Aug 8, 2010 | 03:44 PM
schizcat's Avatar
schizcat
Originally Posted by headhunter1975
Hmm, they replaced my control module, seats work, hud works, just no telescopic steering wheel, or ability to turn off active handling. I did just notice that my left front tire is reading zero pressure, would that affect the ability to turn off active handling?
Dont know if it was already said but yes, if ANY of the tires are reading O psi, it will not let you deactivate AH. 3 things to try:
1) put a small shot of air into the tire and sometimes the sensor will reset
2) pull a cable off the battery for about 5-10 seconds and this will sort of "reset" things
3) recalibrate the TPMS
I had\have the same problem since Ive had the DBS and am currently having the steering column lock issue. I have never had to recalibrate the sensors, but if the other 2 things do not resolve.....
Also, if recalibrating doesnt fix, then you might have a bad TPMS
