Vararam Installation????
Old Apr 11, 2008 | 09:17 PM
msh1862's Avatar
msh1862
Default Vararam Installation????
Anybody have pics of their step by step install. I cannot remove the plastic baffle between the radiator/condenser and the OEM intake.
Show me what you can. Many thanks in advance.
Old Apr 12, 2008 | 10:57 AM
aquaman's Avatar
aquaman
msh1862,
I installed a Vararam on my 07 A6 last week-end. I used instructions
from a place called Shocker Racing that I thought were pretty good.
http://www.shockerracing.com/forum/v....php?f=11&t=65
I'm not sure what the plastic baffle is that you are referring to. Is it the shroud, which needs to be cut? I used a boxcutter to cut mine out with it left in place. I had the razor out to the first notch only so that it did not reach to the condenser. I did end up cutting out more at the bottom (front) than what it appeared the template showed. It ended up taking me about 2 hours.
Old Apr 12, 2008 | 01:24 PM
ShockerRacing's Avatar
ShockerRacing
Sorry that I have not yet updated my pictures since I redid my website but feel free to PM me with any questions! I am always glad to help. You shouldn't need to remove that shroud unless you bought a precut shroud.
Aquaman, thanks for posting up my write-up!
Old Apr 12, 2008 | 06:24 PM
msh1862's Avatar
msh1862
Thanx for the site and the tips. I thought it would be more exact to cut the plastic baffle in front of the Condenser/radiator if it were out of the car. Site says no. One site showed a propane torch. Little scary with an aluminum coil.
Will update and asked as needed.
Old Apr 13, 2008 | 12:06 AM
HOXXOH's Avatar
HOXXOH
Originally Posted by aquaman
msh1862,
I wish I'd seen those instructions before I installed mine. What a fight. I agree the template was incorrect along with real poor photos and incomplete instructions. Be careful to clean everything before installing, so you don't ingest crap.
Old Apr 13, 2008 | 09:41 AM
jrpedraza's Avatar
jrpedraza
I hope your install has gone well, I installed mine two weeks ago - what a pain in the A$$ removing the shroud was. I saw in the instructions that I could have left it in place but opted to fight with it to remove it.
What I really did/do not like about the Vararam is the flimsy rubber connectors that hold the unit together; I caught hell getting them in place the first time, then they kept coming off when on the car. That design definitely needs to be reconsidered.
JR
Old Apr 13, 2008 | 12:30 PM
Ralphyboy's Avatar
Ralphyboy
St. Jude Donor '08-'09
Find Cajundudes install instructions.They are very detailed, and have alot of photos. If you look at them carefully, and take your time, it will work out fine. Be sure to jack up the car correctly to gain access to the underside, and if you have a K&N filter that comes with it, be sure to check to see if it must get oiled before it's installed. Also, from my own experience, you should seriously think about getting ZO6 screens to prevent anything from clogging up the intake. IMPO they are required for this intake. Forget the about hydrolock, this is just to make sure paper or other stuff doesn't get sucked in because this WILL cause your car to run badly. Also, get a tune with it. Yes, it will work OK without a tune if you just drive it like the instructions say, but a good tune will make a huge difference. Ask me how I know.Enjoy.
Old Apr 13, 2008 | 03:06 PM
slacker1201's Avatar
slacker1201
Lifetime NCM Member #2497
Cruise-In 9-10-11-12 Veteran
JR
I just installed mine last weekend and had a hard time with them too. If you look at my pic mine had come off after the first test drive.
Old Apr 13, 2008 | 11:30 PM
HOXXOH's Avatar
HOXXOH
I've temporarily duct taped my upper half to the lower. The clamps were attached so far out of line that I couldn't even stretch them far enough to fit. I removed the clamps completely as they would have required the shroud to be cut even larger.
I won't have an opportunity to revise the clamp method soon, but will post photos when it's finished.
I noticed you didn't install the spacer either. It certainly would not have fit on mine. Was that your reason too?
Old Apr 15, 2008 | 08:02 AM
Jim Johnson's Avatar
Jim Johnson
What a pain in the a** to install. I ordered their pre-cut shroud, so I could save mine, but boy, was that a mistake. 4 hours later, and I finally have the old shroud out, and the new shroud setting in place. Had to trim the new shroud in multiple places to finally get it to fit. It's designed to go in before the front body work goes on, I guess.
Also instructions really suck. You would think they could come up with something better than that. I don't think they've ever installed one of these using their instructions. It might be a good idea for them to do just that.
My hands and arms also look like I've been trying to give the damn cat a bath. I'm bleeding from more places than I care to count. My wife also got a big kick from all the colorful language coming from the garage. She even asked me to tone it down so I wouldn't offend the neighbors.
Anyway, tonight I get to finish what I started yesterday afternoon. Getting all the fasteners in place, and getting the actual intake on and connected to the throttle body, and a quick shake down run.
BTW, this is on a 07 A6. Kinda makes those CAI's that advertise no cutting and 10 minute installs look a lot better.
To Vararam Installation????
