WOW ... Mich PS2's
Old Apr 26, 2008 | 12:06 PM
kermooni's Avatar
kermooni
Default WOW ... Mich PS2's
The RR tire was losing pressure so I took in to my favorite Chev dealer in the twin cities (Lupient Chev).
A quick look and there was nail in the tire That meant no more HPDE. Since the threads were almost gone, I opted for changing all four to Mich PS2's. The cost $1800 complete with alignment
This seems high except that no other Chev dealer would do it for less than $2200. Thanks Lupient.
The best Part, the ride on the PS2's is awesome - quiet, sticky, much better sterring feel and since it rained Thu an excellent grip on wet roads. Did I mention quiet?
Do you have run craps? dump them for Mich PS2's. It is worth every penny.
Old Apr 26, 2008 | 12:29 PM
PowerLabs's Avatar
PowerLabs
From: Greater Detroit Metro MI, when I'm not travelling.
You and me are in the same boat: I nailed a pothole that ruined my drivers side front, the tires were going bald, I got Michelin Pilot Sport PS2 from Tire Rack for $1400 and paid another $200 to mount and balance them AND to do a full alignment in the car.
Like yourself I noticed a LOT less road noise, less harshness on bumps and MUCH more traction, both in the dry and in the wet. It took about 100 miles for the mold release compound to wear off and now I can go wide open throttle in 1st and not break lose!
I would recommend these tires to anyone: there is a reason they come sock on the new 650HP ZR1
Old Apr 26, 2008 | 01:16 PM
LSCHLEM's Avatar
LSCHLEM
St. Jude Donor '08-'09-'10
How would they work at the drag strip compared to runflats and dr's ?
Are they lighter ?
Old Apr 26, 2008 | 02:06 PM
PowerLabs's Avatar
PowerLabs
Are they lighter ?
24lbs lighter in stock size compared to the Eagle F1 supercards.
Nothing will be as good as a drag radial, but they hook up a LOT better than my runflats did. On the downside, when you do make them spin, they also wheelhop more.
Old Apr 26, 2008 | 02:10 PM
Evilways's Avatar
Evilways
Are they lighter ?
1.87 60ft on runflats, best for rfs, but a one time deal.
1.86 60ft on PS2s, consistant , duplicated several runs in a row.
1.85 60ft on MT DRs , consistant in mid to high 1.8's
you can lower the psi in the PS2s to 24psi cold before hitting the track to eleminate the wheel hop concern, as well as doing a smokey burnout. With the runflats, the lowering of psi helped alomost nothing as the sidewall was like stone.
Old Apr 26, 2008 | 05:43 PM
SeanMo's Avatar
SeanMo
St. Jude Donor '10-'11
They were probably so expensive because you got it done at the dealership.
Old Apr 26, 2008 | 08:43 PM
keyplyr's Avatar
keyplyr
Although I went with Toyo T1Rs. I went to 19" front and 20" rear with my new wheels. At the time, the Michelin Pilot Sport PS2 in that size were not in production and there was no projected date yet. From what I hear, they're still not. Maybe by the time I wear these out...
IMO almost any non-runflat will be an improvement. I was thrilled to finally get a responsive, sticky performance tire with no wheel-hop!
Old Apr 26, 2008 | 09:22 PM
Hoonose's Avatar
Hoonose
Almost any new RF tire will be quieter, smoother and grippier than an old and hardened wore out RF. Plus you don't lose the other good attributes of RF tires when switching to non-RF tires. I would take careful before and after experiments to quantitate the difference.
Old Apr 27, 2008 | 01:29 AM
keyplyr's Avatar
keyplyr
Originally Posted by Hoonose
...good attributes of RF tires
oxymoron
Old Apr 27, 2008 | 02:09 AM
jogar80's Avatar
jogar80
So are PS2's also runflats or not?
Old Apr 27, 2008 | 02:13 AM
kermooni's Avatar
kermooni
Nope ...
Old Apr 27, 2008 | 09:30 AM
PowerLabs's Avatar
PowerLabs
Mine aren't either, but there IS such a thing as run flat PS2s: they come on the ZR1.
Old Apr 27, 2008 | 11:10 AM
nhpln's Avatar
nhpln
Michelin is making PS2 ZP (aka runflats) in stock C6 and C6Z06 sizes. Should be available by Fall.
Old Apr 27, 2008 | 11:24 AM
kermooni's Avatar
kermooni
Thanks. I guess I will consider them for the next set.
Old Apr 27, 2008 | 12:03 PM
Wingrider's Avatar
Wingrider
True, until you have a flat late at night in a thunderstorm. Happened to me in Chicago. Think I will stay with the run flats.
Old Apr 27, 2008 | 05:30 PM
Boomer111's Avatar
Boomer111
Expect accelerated tire wear, grip comes with a price. I ran through the rears at 8,000 miles on the M3 with the Pilot Sports. Thats with no launching or wheel spin.
Old Apr 27, 2008 | 05:41 PM
PowerLabs's Avatar
PowerLabs
Wow. I thought these would be good for about 20,000 miles; that's how long the stock run flats laster on my car by the time they were bald... I guess we will see.
To WOW ... Mich PS2's
Old Apr 27, 2008 | 08:09 PM
EuroRod's Avatar
EuroRod
Have the PS2's on my ProCharged C6. Great summer tire. Winter comes, and they'll try to kill you! Any temps below 40 degrees and the grip is gone, and they will not recover from an oversteer slide. Period. I wiil change to some kind of winter tire before next winter. Bad part about living in Tennessee is that one day it's 70 degrees, next day is 25 degrees.
Old Apr 27, 2008 | 08:16 PM
keyplyr's Avatar
keyplyr
Originally Posted by EuroRod
.... Bad part about living in Tennessee is that one day it's 70 degrees, next day is 25 degrees.
Must keep your wardrobe choices interesting
Old Apr 27, 2008 | 09:29 PM
Vetteoholic's Avatar
Vetteoholic
Excellent choice of tire I just wish they were cheaper, but what can you do. PS2's are the best tires I've ever owned hands down.
I will buy again and again.
