Breaks Squeak
Old Apr 28, 2008 | 07:44 PM
doobee's Avatar
doobee
Default Breaks Squeak
Hi all,
I have a 2007 C6, automatic, no accidents, with 13,000 miles on it. I got this car new from a dealer and it is under warranty. My breaks started squeaking 6 months into my purchase. They start squeaking after few minutes of driving and only squeak if I press the breaks softly, if I have to break a little harder they do not squeak at all. I have been to the dealer 5 times. First they just cleaned my breaks, next they resurfaced the rotors, and few weeks ago they changed my pads but that still did not help.
I will be going back to the dealer soon but I have no idea what they can do at this point and it’s been a pain going to the dealer and wasting a whole day there.
What can it be and what can I do???
Thanks,
Eugene
Old Apr 28, 2008 | 08:29 PM
combatvet's Avatar
combatvet
I had the same thing happen 2 me 07 a6 and the dealer told me show me a Vette that doesn't have that problem. Now I'm in an 08 and no problem.
Old Apr 28, 2008 | 08:30 PM
Tom_Slick's Avatar
Tom_Slick
Originally Posted by doobee
Hi all,
What can it be and what can I do??? Less than $150/ set.
Thanks,
Eugene
I highly recommend ceramic pads! I had the same problem... After I ordered a set of drilled/ slotted rotor, I also added a set of ceramic pads.... No more squeaking/ squealing!
Old Apr 28, 2008 | 08:41 PM
NYC6's Avatar
NYC6
B*R*A*K*E*S Come on guys, we're car people.
Old Apr 29, 2008 | 12:27 PM
jpgolf14's Avatar
jpgolf14
lots of folks with the stock semi-mettalic brakes have the noise problem. i went to the GM ceramics from Gene Culley, and while i still occasionally get some noise, it is mostly gone, and a side benefit is reduced dust. of course if you are going to track your car you probably dont want to use the ceramics.
Old Apr 29, 2008 | 01:00 PM
doobee's Avatar
doobee
Thank you all! It looks like I will either get ceramics or just live with the noise (probably stick with current pads since I take my car to the track sometimes). At least I will not waist my time going to the dealer anymore. Very disappointed though :-(
Old Apr 29, 2008 | 03:32 PM
JLargo's Avatar
JLargo
My stockers squeal to. I just hit them real hard a few times and they quit.
Old Apr 29, 2008 | 09:39 PM
BlueFish81's Avatar
BlueFish81
I have a noisy one to and mine is a 08 with 5k miles.
Old May 2, 2008 | 11:46 AM
doobee's Avatar
doobee
I've hit my breaks real hard before... been to Willow Springs twice...still squeak.
Old May 2, 2008 | 11:52 AM
Dave S's Avatar
Dave S
Retired & lovin' it!
Brake squeal seems to be an on-and-off problem with different model years. One solution that may work for you is to apply a VERY thin coat of high heat moly grease to the back sides of the pads.....
Old May 2, 2008 | 02:42 PM
cody6.0's Avatar
cody6.0
Also the Z51 pads tend to be a little more noisy than base pads. That could be why people say some squeak some don't also.
Old May 2, 2008 | 02:51 PM
User 81424's Avatar
User 81424
Bed the pads. Do a search.
Old May 2, 2008 | 03:06 PM
mksz51's Avatar
mksz51
Put the ceramics on - permanent fix. The other common suggestion is "bedding" the pads - that is NOT a permanent fix.
Old May 2, 2008 | 04:23 PM
Johnny vette's Avatar
Johnny vette
Default my way will work.................................... ...............
Raybestos Quiet brake pads. cost under 100 dollars....You will thank me later........
To Breaks Squeak
