Fire Extinguisher Mount
Old May 1, 2008 | 08:33 AM
Gman57's Avatar
Gman57
Default Fire Extinguisher Mount
I'm looking for some different chioces of Fire Extinguisher Mounts.
I found the BK front seat mount..... does any other manufacture make a mount like this? I'm looking for something that would be easy to remove in and out as this would only be needed on race days.
Looking for your input.
Old May 1, 2008 | 10:52 AM
Wayne O's Avatar
Wayne O
CF Senior Member
Check Livermore Performance and/or Safecraft...I believe they have some different styles.
I'm actually looking for a fire extinguisher mount now....I will either mount it to my BK harness bar or most likely, down low in front of the passenger seat.
I've got a fire extinguisher now with a quick release wall mount. I have to see if it's acceptable but I could probably mount it to the harness bar with band clamps.
Let us know what you end up doing. Good luck.
Old May 1, 2008 | 01:01 PM
scottycards's Avatar
scottycards
St. Jude Donor '08 thru '13
Gman-
I just made one for open road racing. Cost me about 15 bucks. I can snap some photos for you later when I get home if you want.
1. Home Depot, 16 gauge steel piece, about 6 in wide, and 12 in long. 6 bucks.
2. Metal fire extinguisher bracket from these guys- mine was for a 2lb bottle, but they have ones for all sizes- cost me $10.
https://www.selectsafetysales.com/p-...et-466401.aspx
3. One cutting wheel on my 4" grinder- maybe a buck or two.
4. I beveled the edges and rounded the corners, so no sharps, and painted flat black with some spray paint in the garage.
4. I'm not an artist, but here is what it looks like. Pride of making my own bracket, and some dough in my pocket for gas.
Hope this helps. Took me maybe 30 minutes, and I felt very "Monster Garage" while doing it. I bent the tabs on a 2X4 with a hammer on the floor of my garage. Easy stuff.
I can remove this piece by loosening the two seat bolts, takes maybe 5 minutes.
Old May 1, 2008 | 04:48 PM
Gman57's Avatar
Gman57
I have been told about one the slid in the tracks of the seat slide with having the seat all the way back (passenger side) to remove power the seat forward and it will slide right out!!!! I may have to make this one myself......... I like this idea of easy in and out
scottycards... shoot a few snaps and show us what you got!
Old May 2, 2008 | 11:37 AM
scottycards
Gman,
Sorry, didn't see your post last nite, and I'm back at work. Will do tonite.
If you're not in a particular hurry, I'd be happy to make one for you- all you'll have to do is attach the metal bracket of your choice.
I have some time on Sunday, and could mail to you. Will post pics this evening for you. Just let me know.........it's a clean install.
Old May 2, 2008 | 06:44 PM
calemasters's Avatar
calemasters
Old May 2, 2008 | 10:09 PM
Gman57's Avatar
Gman57
Originally Posted by scottycards
Gman,
Scotty-
Thanks for your offer... You got me going! I've fabed up a protype and going to get some .100-.125 aluminum should have somethimg fabed up next week!
Old May 3, 2008 | 07:49 AM
scottycards
Aluminum? Gettin' fancy on me. Mine is 16 ga steel, about .060". You should use diamondplate for ultimate bling factor. Hmmmmmmmmm...........
The satisfaction of making your own, coupled with the savings, is very rewarding, and makes for good conversation at the track with your buds.
Here you go:
And a final addition- my <$20 camera mount. I bought a window-mount spotting scope holder at Sportsman's Warehouse ($12.95) that my camera screws onto that clamps right on to this little gem......couple of U-bolts with shrink tube, a mousepad scrap under the plate for vibration dampening, and great video from in the car!
Finally, what does all this work (HA!) get me? The satisfaction of passing tech to run up to 165MPH (which we did) at the Big Bend Open Road Race last weekend!
Old May 3, 2008 | 10:17 AM
Gman57's Avatar
Gman57
All Very nice!..... 165MPH that sounds like fun.
We need video
Congrats on a great track day!
Old May 3, 2008 | 11:19 PM
vettedan's Avatar
vettedan
Vetteworks offers a fire extinguishers mounting bracket that installs on the front passenger seat of 1997 through 2008 Corvettes. The bracket fasten to the front two seat rails and can be installed or removed in seconds without tools. The bracket must be installed with the seat adjusted fully back. There will be a small amount of forward seat adjustment on power seats once the bracket is in place. The bracket will accept only Amerex fire extinguishers from 1.0 lbs up to 2.5 lbs. The Vetteworks Extinguisher bracket is constructed through a precision lazer machined process and are powder coated with matt (flat) finish. High quality chrome finish is now available. bracket come with detailed instructions. GM exclusive uses Vetteworks C605 Brackets in all of their official 2006 C6 Z06 Brickyard 400 and Indy 500 pace Corvettes.
http://www.vetteworksonline.com/cata...roducts_id=115
To Fire Extinguisher Mount
