Header Installation - Question
Old May 6, 2008 | 03:23 PM
JRingHookEm's Avatar
JRingHookEm
8th Gear
Default Header Installation - Question
I recently had Kooks 1 3/4" headers, X-pipe, and a tune installed on my 07 C6 A6. I absolutely love the performance gains and the new sound! My question though, is that the fan seems to be running much faster than before when the car is at idle. Is this "normal"? If so, is there anything that can be done to calm it back down?
Thanks for your help!
Old May 6, 2008 | 04:08 PM
Smoke20's Avatar
Smoke20
Default Fan
Faster?...or more frequently?
Old May 6, 2008 | 04:32 PM
JRingHookEm
8th Gear
Seems to be running faster
Old May 6, 2008 | 04:49 PM
IPS Motorsports's Avatar
IPS Motorsports
They should not be running faster, only way to have this is to increase voltage.
Frequently may be, due to hotter coolant temps if this is occuring
Old May 6, 2008 | 07:28 PM
haljensen's Avatar
haljensen
Fan temp on/off and % of speed were set by your tuner. Check with them for their reasoning and settings.
Old May 6, 2008 | 07:47 PM
oneblackvette's Avatar
oneblackvette
I agree tuner got a little too heavy with the fan speeds
Old May 7, 2008 | 08:03 AM
Zig's Avatar
Zig
From: stafford country, va. Avatar: Me on turn 3 @ Bristol (The World's Fastest Half-Mile)
Old May 8, 2008 | 10:00 AM
jrpedraza's Avatar
jrpedraza
Since it's gotten pretty warm in Houston, your tuner probably thought you would need the additional cooling? How have your engine temps been?
Talk to your tuner and go from there...
JR
Old May 8, 2008 | 11:01 PM
C5pilot's Avatar
C5pilot
If your tuner went beyond 25% in the 192* cell, the fan will run at full speed all the time even after it drops below 192*. Don't ask why, just ask him to lower the 192* back down to something like 20%.
Here's a test..., after reaching operating temp, if you see the temp drop below 190* and the fan is still at high speed, it's your tune, and easily fixed.
Also, keep in mind your fan SHOULD run faster (and more often) while at idle because it's the only thing moving air across the radiator. Once you start to move you get maximum cooling without the fans help. But the fan should slow down regardless if the temp's below 192*.
To Header Installation - Question
