Anyone have a roll CAGE?
Old May 8, 2008 | 10:23 AM
Jorday's Avatar
Jorday
Default Anyone have a roll CAGE?
Note that I said roll CAGE not roll BAR.
I need a fully NHRA legal 10 point roll cage for my C6Z. Anyone know where one can be had?
Old May 8, 2008 | 01:11 PM
johnodrake's Avatar
johnodrake
Moderator
You might call Wolfe Race Craft. They have cages for C5s on thier site but they told me they were working on C6 stuff when I asked about a Bar for C6 Verts.
Old May 8, 2008 | 01:53 PM
SoldSyclone's Avatar
SoldSyclone
10 point do we have the first C6Z06 in the 8's ???
Do tell
Old May 8, 2008 | 02:21 PM
FordDefector's Avatar
FordDefector
The best thing to do is find a good guy that builds cages and understands what is required to pass tech and have a custom cage installed in your car. You will end up with a cage that fits the car better than a kit and maximizes how much room you have left in the car with the cage.
Old May 8, 2008 | 04:42 PM
Jorday's Avatar
Jorday
I spoke with Wolfe, nothing available for the C6 yet from them.
Do tell
8's would be a tall order, but a 10 point roll cage is required in all vehicles running 9.99 or quicker and any vehicle running 135+ in the 1/4 mile regardless of ET. I do think it'll run well into the 9's at over 150, but at this point it's nothing but speculation.
427 ci Warhawk block
All Pro LSW 6 bolt heads (400+cfm)
Solid roller cam
Jesel shaft mount rockers
Sheet metal intake with 100 mm TB
F1C procharger
7500+ rpm redline
Few basics there...lot more stuff will be added obviously...
I've been on the phone calling a few places, and have run into nothing but dead ends so far.
Old May 8, 2008 | 05:42 PM
racerx8's Avatar
racerx8
Call Randy at DRM, they do SCCA cages and I know they have the talent to help you.
Old May 8, 2008 | 05:43 PM
C6400hp's Avatar
C6400hp
From: DFW This user does not support or recommend the product or service displayed in the ad to the right
How about LG motorsports or phoenix performance? I am sure out of the two they both now how to build a proper cage.
Old May 8, 2008 | 05:59 PM
Bobby @ LG Motorsports's Avatar
0Bobby @ LG Motorsports
Former Vendor
We just finished a C6Z BAR yesterday, adding the additional 6 points would not be hard, but would require a lot of time and fabrication with the aluminum frame. Do you have the ability to Tig weld aluminum?
Louis
Old May 8, 2008 | 06:25 PM
racerx8's Avatar
racerx8
Did not mean to leave anyone out I was thinking of proximity to OP.:o
In fact, Joe Aquilante at Phoenix built my SCCA T-2 Camaro and helped me with my SCCA T-1 C5. DRM did the initial build of the T-1 C5.
...and yes LG is very qualified also as are many others here.
Good luck.
Old May 8, 2008 | 08:27 PM
Jorday's Avatar
Jorday
Louis
Hey Louis,
It was nice talking with you today. Sounds like a good deal that we worked out. I'll be looking forward to hearing back from you.
Jordan
Old May 9, 2008 | 03:19 PM
Stage IT's Avatar
Stage IT
I have a question... what type of material is being used for the cages cause i have always heard welding steel and aluminum is a no no...are the cages that people are doing aluminum....or bolt in on the C6 Z
Old May 9, 2008 | 07:18 PM
Jorday's Avatar
Jorday
You can't weld aluminum to steel. The right way to do it is probably to weld aluminum mounts to the frame and then bolt the cage to said mounts.
Aluminum is not a approved NHRA material for roll bars or roll cages.
From the NHRA rule book...
A roll bar must be constructed of minimum 1 3/4 x .118 wall thickness mild steel tubing or 1 3/4 x .083 thickness chrome moly steel.
A roll cage must be constructed of minimum 1 5/8 x .118 wall thickness mild steel tubing or 1 5/8 x .083 wall thickness chrome moly steel.
To Anyone have a roll CAGE?
