X-Pipes??
Old May 8, 2008 | 02:49 PM
LAZLOW's Avatar
LAZLOW
Cruising
Default X-Pipes??
Does anyone know of a company that makes an x-pipe for a 06 C6 with the A6 paddle shift trans? I've seen various companies that make one, but none of them will fit my trans appearently, can anyone help?
Old May 8, 2008 | 04:45 PM
davekp78's Avatar
davekp78
C1 of Year Finalist (stock) 2019
2016 C1 of the Year Finalist
2015 C2 of the Year Finalist
I have a Borla X-pipe w/ GM off road catback. Fits fine.
Old May 9, 2008 | 09:59 AM
haljensen's Avatar
haljensen
All aftermarket X Pipes I've seen terminate at the same point as the stock H Pipe. The axle back portion is the problem with the A6. You need an X Pipe that bolts to your existing exhaust manifold/header/cats.
If you have stock headers/cats look into a stock '08 replacement X Pipe.
If you have headers/cats (or cat delete) you will have to purchase the X Pipe from the header manufacturer.
Old May 9, 2008 | 12:04 PM
Tony @ MPH's Avatar
Tony @ MPH
Supporting Vendor
I can get you a B&B X-pipe for your C6 that will fit without issue.
Give us a call.
800-364-1975
Thanks,
Tony
Old May 9, 2008 | 06:41 PM
The Six's Avatar
The Six
Check out a company called Dr. Gas. They just built me a custom x pipe for my set up. Called the Tandem Crossover on their website. See: www.drgas.com. Good luck
Old May 9, 2008 | 10:14 PM
o0 zeno 0o's Avatar
o0 zeno 0o
which ones are you saying won't fit? All of them should. If your doing a header/x-pipe job yourself, I would recommend Kooks.. They tend to need very little tweaking to get on there.
To X-Pipes??
