180 degree T stat from Hypertech
May 8, 2008 | 02:57 PM
I was going to buy Hypertech 1015 180 degree Thermostat, their catalog says it fits 2002 or earlier LS1's. Will this work on my C6 Z06?
I had an 01 Z06 and had a 160 thermostat but I felt it took to long for the car to warm up.
Vendor recommendations OK too. Thanks in advance!
May 8, 2008 | 04:44 PM
C1 of Year Finalist (stock) 2019
2016 C1 of the Year Finalist
2015 C2 of the Year Finalist
May 8, 2008 | 04:46 PM
It is different. It won't fit.
May 8, 2008 | 04:48 PM
just open some boxes at the local auto parts store and find one that fits for under 2$.
May 9, 2008 | 01:20 AM
Quote:
Originally Posted by
danl72
Thanks for the info. I'll just hit up one of the vendors for one.
May 9, 2008 | 01:27 AM
Zed_six
I had... a 160 thermostat but I felt it took to long for the car to warm up.
One of the down sides of a 160°. I switched my OEM stat to a 180° and tunned and am pleased with the results.
May 9, 2008 | 02:19 AM
huckleberrydude
I'm too lazy to do that. Do you have a part number?
May 9, 2008 | 02:20 AM
Which vendor did you go with?
keyplyr
May 9, 2008 | 07:03 AM
Zed_six
Can't remember, sorry
May 9, 2008 | 07:36 AM
huckleberrydude
Bad advice. They probably won't have the type required. It is different from most other cars.
May 9, 2008 | 10:03 AM
St. Jude Donor '08
I stove tested several brands of tstat and the only ones that opened correctly were the stock one and the Lingenfelter 165. I'm not sure what your goals are but I didn't see any difference in running temp vs stock with a 180 stat.
May 9, 2008 | 10:18 AM
What's stock on a z51 08?
May 9, 2008 | 02:23 PM
St. Jude Donor '08
jesse12804
187
May 9, 2008 | 04:10 PM
Your Z06 has 186.6 degree stock. what do you think you're going to gain with 6.6 degrees, besides nothing. I have run 160's LS motors since 1999. never a problem. Put a 160 in. So it takes more time. Are you in a hurry? The long range benefits far out weigh the extra time it takes to heat the motor.
May 9, 2008 | 08:55 PM
dave pawlowski
nope. sorry but you are wrong.
May 10, 2008 | 07:50 AM
huckleberrydude
I stand by my answer. Any other opinions?
May 10, 2008 | 08:09 AM
dave pawlowski
One of you is correct.
I bought one made for my car from.....I don't remember.
May 10, 2008 | 09:15 AM
Get one for a "late LS1". Mr Gasket brand works great, $17.00 special order from any local auto parts store.
May 10, 2008 | 11:46 AM
Thanks!
ANY VENDOR ON HERE I.E. ECS,LPE,CALLAWAY can sell you a 160 stat for around 25-30 bucks shipped.Then you get a DIABLO and adjust the fans to come on sooner and thus the car runs cooler.They tell me it makes a little power or something,but I'm not 100% convinced!
May 10, 2008 | 09:19 PM
I'll have to find the number. $1.97 from autozone
