Proper Voltage?
Old May 9, 2008 | 09:56 AM
Captainkelp's Avatar
Captainkelp
Default Proper Voltage?
Just curious what is the proper voltage that I should be seeing for my 06 A6. Sometimes I check it and it is 14.5, and other times it hangs around 14.1-14.2. Is this normal?
Old May 9, 2008 | 10:55 AM
oldman's Avatar
oldman
Yes, It's very normal. The different voltages depends on the RPM of the engine and if the battery is fully charged.
Old May 9, 2008 | 11:07 AM
C6~Missle's Avatar
C6~Missle
Yep... you're right in the range where it should be..
Old May 9, 2008 | 03:13 PM
VET4LES's Avatar
VET4LES
Your seeing the normal range.
To Proper Voltage?
