AHS in Comp mode = faster??
Old May 11, 2008 | 11:24 AM
Migs08's Avatar
Migs08
Default AHS in Comp mode = faster??
Will competition mode give you faster accel times vs. full AHS??
Seems to me, wheel spin would hinder flat out acceleration--
I don't get it. Can someone explain? thanks.
Old May 11, 2008 | 11:34 AM
patton's Avatar
patton
St. Jude Donor '09
TC really slows ya down ,as ya get to know the car you can do better with TC off. as far as AH you really REALLY have to know the car to get yer butt out of trouble.at the drags i run both off,on the street i rarely touch the double death button
Old May 11, 2008 | 06:26 PM
SoldSyclone's Avatar
SoldSyclone
It depends on tires and road surface buy a Gtech and test it on with your combo to know for sure
If you have too much tire spin TC on should be faster.
Old May 11, 2008 | 07:10 PM
LostAngel's Avatar
LostAngel
I always drive around in comp mode....it's part of my 'turning the car on' ritual.
1) open door
2) shut door
3) seatbelt
4) turn car on
5) turn comp mode on
Old May 11, 2008 | 07:52 PM
timafey's Avatar
timafey
1) open door
2) shut door
3) seatbelt
4) turn car on
If you notice, you can really feel the power die off towards the top with TC on, almost as though its reving but not going anywhere. Hence more reason to keep it off... Just dont floor it in 90* turn and you should be fine
Old May 11, 2008 | 10:57 PM
Gray Ghost GS's Avatar
Gray Ghost GS
"AlohaC5" Senior Member
Once you become proficient in performance driving in your vette on the road courses - you'll be much faster with both the AH and TC turned off. The car becomes much more predictable under more "extreme" driving conditions. All you need is the ABS. However, I leave TC/AH on for daily driving, especially when its raining. Mike
Old May 12, 2008 | 05:37 AM
Zig's Avatar
Zig
From: stafford country, va. Avatar: Me on turn 3 @ Bristol (The World's Fastest Half-Mile)
yes and no, it depends.
t/c limits wheel spin by reducing engine output (a/h uses the brakes instead).
if all you did was stomp and stand on the 'go fast pedal' t/c enabled will provide better acceleration (it'll peddle for you )
on the other hand, t/c off will permit you to take it to the edge (of traction) and peddle it yourself.
To AHS in Comp mode = faster??
