Funny Electrical Problem - Window Indexing
Old May 20, 2008 | 08:02 PM
KMorris's Avatar
KMorris
Default Funny Electrical Problem - Window Indexing
Greetings - before I run off to the dealer or start the troubleshooting process I wanted to check and see if anyone else has had this problem.
Car - '07 C6 Z51 17,500 Miles
As the story goes....all of a sudden my passenger door window began to 'index' up and down. It will even do this dance with the engine turned off. I can stop this behavior by rolling down the window and leaving it down a bit.
And of course the door won't open from the inside or outside now. I do have the factory service manuals I'm just wondering if anyone else has solved this before I begin.
Keith
Old May 20, 2008 | 08:05 PM
danl72's Avatar
danl72
Could be an electrical short or something wrong with the motor.
Old May 20, 2008 | 10:37 PM
tpereira's Avatar
tpereira
mine did something like this for a day. went away before i could get it to the dealer
Old May 21, 2008 | 07:55 AM
foremaw's Avatar
foremaw
Active Streak: 90 Days
St. Jude Donor '08-'09-'10-'11-'12
I believe others have had success by disconnecting the battery then reconnect and index the windows. Also, you might double check the the connectors between the door and body inside the rubber boot.
Old May 21, 2008 | 08:09 AM
ben dover's Avatar
ben dover
From: When all is said and done... there is a hell of a lot more said than done. Riverside,Texas
St. Jude Donor '05 thru '26
I would try the "reboot" first.
Old May 21, 2008 | 11:55 AM
KMorris's Avatar
KMorris
Default Thanks
Thanks for the responses. I tried the 'reboot' and thought I had it until it started again. I'm hoping to find and inspect the connector. Indexing while the power is off might make it a bit trickier.
If I find anything interesting I'll post the results.
Keith
Old May 21, 2008 | 06:50 PM
Chevtech's Avatar
Chevtech
This should do the trick, almost always the drivers door switch but it can be either one.
#08-08-64-001A: EI08034 - Power Window/Regulator Concerns, Inoperative, Intermittent, Indexing, Continuous Up and Down (Diagnose Door Handle Switch, Replace if Necessary) - (Apr 8, 2008)
Subject: EI08034 -- Power Window/Regulator Concerns, Inoperative, Intermittent, Indexing, Continuous Up and Down (Diagnose Door Handle Switch, Replace if Necessary)
Models: 2007-2008 Cadillac XLR
2007-2008 Chevrolet Corvette
This bulletin is being updated to end the need for diagnostic information and to provide field fix information. Please discard Corporate Bulletin Number 08-08-64-001 (Section 08 -- Body and Accessories).
Condition
Some customers may bring their vehicles into the dealership for a concern relating to the operation of their power windows.
Correction
Diagnose the exterior door handle switch as a possible cause for this condition. If diagnosis confirms the condition is caused by the exterior door handle switch, replace both driver and passenger switches. Be sure to mark which switch comes from the driver and passenger doors. Parts will be requested back through the Warranty Parts Center return process.
Parts Information
Part Number
Description
10446243
Front Side Door Handle Switch
Old May 21, 2008 | 06:53 PM
knkali's Avatar
knkali
Chevtech
Old May 21, 2008 | 07:52 PM
KMorris's Avatar
KMorris
Default Thanks Chevtech
It appears that my problem may reappear even if I think it's gone away. Your post is invaluable!
Thanks,
Keith
Old May 21, 2008 | 07:53 PM
*FAÇADE*'s Avatar
*FAÇADE*
PHOTOSHOP SPECIALIST
St. Jude Donor '07-'08-'09-'10-'11-'12-'13-'14-'15-'16
Originally Posted by knkali
Chevtech
Old May 21, 2008 | 10:09 PM
Vettlldo's Avatar
Vettlldo
It can be annoying. One of our club members went out to wash his Z06 and discovered after pouring water over the top that the indexing didn't happen the night before. Whoops...took lot's of towels to mop up the mess.
Old Jun 15, 2008 | 12:58 PM
KMorris's Avatar
KMorris
Default Results
It took two visits to the dealer to solve this issue(s). First the car was returned with a reprogrammed Body Control Module (BCM). Some reference was made to my Clifford aftermarket alarm system - signal crossover or something. I've had my aftermarket alarm for a year and don't use it and this is a recent problem. But anyway, the reprogramming seems to have worked. However, the passenger door still refused to open. Back to the dealer (he forgot about the door - really - I had written out the problems so they might be easier to recreate) and the door switches were replaced.
Now doors open and windows go up and down right.
Keith
To Funny Electrical Problem - Window Indexing
