Doors will not open!!!!!
Old May 25, 2008 | 01:58 PM
SPDKLZ's Avatar
SPDKLZ
2016 C5 of Year Finalist
Default Doors will not open!!!!!
I started having this problem a couple of days ago. My doors are not releasing and I have no idea what is going on. I have been locked out of my car a couple of times and it is annoying.
It seems as though it is locking itself. Sometimes I have to hold the press pad for 30 seconds or more and even then it is infrequent that the door actually opens. My passenger door will not open at all unless I open it from inside the car. Yes, from inside they open without a problem at all.
Is there a possibility that my FOB is causing it to lock/unlock? There were a couple of times where the window came down as if it was opening, but thedoor would not open.
I did notice that both hinges are not striking properly...could this cause the press pad to not function properly if the doors are out of alignment?
Rodrigo
Old May 25, 2008 | 02:45 PM
johnodrake's Avatar
johnodrake
Moderator
There have been problems with the RCDLR (Remote Control Door Lock Receiver) that gives this symptom. That is a dealer issue (for most people).
Old May 25, 2008 | 07:00 PM
haljensen's Avatar
haljensen
Lambo doors? Obviously you can't take it to the Dealer.
Probably the latch/striker modification or a wiring problem.
Old May 26, 2008 | 10:52 AM
marcus769's Avatar
marcus769
Yeah... .. Good luck w/ that
Old Nov 27, 2008 | 09:05 PM
boz524's Avatar
boz524
Curious what the resolution to this was? I am having the same issue with my '05.
Old Nov 27, 2008 | 09:36 PM
Jimmyz28's Avatar
Jimmyz28
Had this happen to me in Aug.
Officially from the service invoice:
CO183 FRONT SIDE DOOR WINDOW REGULATOR REPLACEMENT
1 25853811 REGULATOR
1 MISC WARR PU
Old Nov 27, 2008 | 10:07 PM
Corellian Vette's Avatar
Corellian Vette
I had an issue when it was 30 deg outside. Guess vettes dont like being out in the cold
Old Nov 29, 2008 | 11:03 AM
ROD BROWN's Avatar
ROD BROWN
Default My problem is just the opposite
Hi,guys,my problem is just the opposite.I found out last night while Christmas shopping,my doors don't lock.I am thinking it has been like this since I bought it.I tried to reset the locks on the DIC and it won't lock.I guess its time to go to the agency.Any suggestions?
Old Nov 29, 2008 | 11:27 AM
torquetube's Avatar
torquetube
Do you mean "won't lock" or "won't latch?"
If it's the former, what are the symptoms? Remember, if you attempt to open the door with the fob in your pocket, it's going to open whether "locked" or not.
Old Nov 29, 2008 | 04:39 PM
TonyB.96LT4's Avatar
TonyB.96LT4
Was having the problem. Dealer put new batteries in fobs. They've been working OK now but sometimes there is hesitation on the membrane for the door button.
Old Nov 30, 2008 | 11:41 AM
ROD BROWN's Avatar
ROD BROWN
Default Doors
[QUOTE=torquetube;1568015579]Do you mean "won't lock" or "won't latch?"
I closed the doors (latched) and I left my keys in the house,about 20 yards away from the car.Waited about 10 minutes and walked out to my car.The doors were open.I am guessing the doors never did lock.:flag :
To Doors will not open!!!!!
