Wheel weight lost
Old May 27, 2008 | 01:59 AM
adias's Avatar
adias
Default Wheel weight lost
I think I lost one .25 FE weight in the rear right wheel. Should I just get a replacement and stick it there or take it in for balancing?
Old May 27, 2008 | 07:56 AM
MikeyTX's Avatar
MikeyTX
Veteran: Marine Corps
St. Jude 15 Year Donor
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13-'14-'15- '16-'17-‘18-‘19-'20-'21
NCM Lifetime Member
Get it professionally balanced !
Old May 27, 2008 | 10:43 AM
Gearhead Jim's Avatar
Gearhead Jim
St. Jude Donor '13
If you are sure you lost just that one weight, clean up the area and stick another one on; the car can't tell that the weight was missing yesterday.
But if you're not sure, get it rebalanced. Find a shop with the Hunter Road Forece balancing machine, they do a much better job on the big/wide/heavy tires of a Corvette.
Probably covered by warranty?
Old May 27, 2008 | 11:32 AM
Walt White Coupe's Avatar
Walt White Coupe
I'd take it up to 80 mph and see if it shakes. No shake, no problem. If it shakes try adding the weight and retest.
To Wheel weight lost
