can u help?
Chevrolet Corvette | Chevrolet Corvette Owner Manual | Service and Appearance Care | Bulb Replacement | Repair Instructions | Document ID: 1471384
Headlamps, Front Turn Signal, and Parking Lamps
High-beam Headlamp
Low-beam Headlamp
Front Parking/Turn Signal/Daytime Running Lamp (DRL)
If the low-beam headlamp needs to be replaced, you will need to see your dealer. See High Intensity Discharge (HID) Lighting for more information.
To replace a high-beam or front parking/turn signal/DRL bulb:
Turn the wheel to allow access to the wheel well.
Access the high-beam or front parking/turn signal bulbs by removing the access panel. To do this, remove the three outer fasteners and move the cover back.
Remove the outer cover to expose the high-beam headlamp bulb socket once the access cover has been removed.
Remove the headlamp bulb by releasing the outer tabs from the socket.
Remove the front parking/turn signal bulb by turning the bulb socket counterclockwise.
Replace the high-beam headlamp bulb with a new bulb and reattach to the bulb socket.
Replace the front parking/turn signal bulb by turning the bulb socket clockwise.
Reverse the Steps 2 through 4 to reinstall.
© 2008 General Motors Corporation. All rights reserved.
