Question about Z-51 disc
Old May 29, 2008 | 09:06 PM
y2k2com's Avatar
y2k2com
Default Question about Z-51 disc
Can someone tell me I ordered from a supporting vendor some Z-51 drilled discs and brackets gm oem , notice that they are the same for both sides so one side is ventilating and the other one not ? Am I missing somthing here thanks for your help.
Old May 29, 2008 | 09:11 PM
timd38's Avatar
timd38
That is how GM does it. You have the correct parts.
Old May 29, 2008 | 09:14 PM
y2k2com's Avatar
y2k2com
Really ? Should there be one on a specific side ?
Old May 29, 2008 | 09:21 PM
C6400hp's Avatar
C6400hp
From: DFW This user does not support or recommend the product or service displayed in the ad to the right
Yes there should but, there is not on the factory parts.
Old May 29, 2008 | 11:26 PM
LS3FORME's Avatar
LS3FORME
It is pretty common, my lotus elise had the same thing, one rotor seemed correct the other was identical and backwards. It had no neg.effect, the z51s are the same, the 08 piece look good, the 08 z51 have larger cooling vents ducts in front and rear vents with plastic vents blowing on the rotors. The front rotors look beefie, if they crack they are cheap enough, will hold out for two piece units and get the most out of these.
Old May 30, 2008 | 07:52 AM
y2k2com's Avatar
y2k2com
Thanks everyone that reassures me
To Question about Z-51 disc
