Nitrous Questions
Old May 30, 2008 | 10:27 AM
rockstarZ06's Avatar
rockstarZ06
Default Nitrous Questions
I just purchased a dry setup off of my buddies car. I am not familiar with dry kits. I have had wet kits before but this is the first dry. Ok so here are my questions
1. His was a auto and mine is a 6sp is there anything that I may need different. He said we are just going to buy a credits and use the tune programs he has. Is that ok with the trany difference?
2. What safety features should I have and which ones MUST I have?
3. Where is the best place to tap into the ignition wire?
4. Where does everyone tie in the WOT switch?
Thanks for the help everyone!!!!!!
Old May 30, 2008 | 11:20 AM
FloydSummerOf68's Avatar
FloydSummerOf68
1. yes, that's fine
2. no safety equipment is absolutely necessary for a kit to work. You SHOULD have an arming switch, WOT switch, fuel pressure safety switch, and window switch. Some tracks will require that you have a blowdown tube. You will also need rollbars if your car runs quicker than 11.5000 at a track.
Old May 30, 2008 | 11:44 AM
rockstarZ06
What plugs does everyone run?
Old May 30, 2008 | 11:46 AM
jogar80's Avatar
jogar80
At the very least get a window switch and WOT TPS switch. Use the purple wire at the throttle body for the TPS, and the white wire at the ECM for the tach signal to the window switch.
Old May 30, 2008 | 11:59 AM
pwoolford's Avatar
pwoolford
St. Jude Donor '08
Get your reading glasses out...
http://forums.corvetteforum.com/show...hlight=nitrous
Old May 31, 2008 | 12:24 PM
SoldSyclone's Avatar
SoldSyclone
http://forums.corvetteforum.com/show....php?t=1719995
To Nitrous Questions
