After lowering my C6 issue
Old May 31, 2008 | 11:34 PM
BlueFish81's Avatar
BlueFish81
Default After lowering my C6 issue
I lowered my 08 C6 by turning the bolts and cutting the rear rubber bushings. The car looks great. The issue is there is squeaking because I cut the rubber bushing from the rear. Is there anything I can do to eliminate this? Or am I stock with it?
Thank you.
Karn
Old May 31, 2008 | 11:42 PM
Keith N's Avatar
Keith N
Did you cut the rear bushings all the way or half of the bushing?
Old May 31, 2008 | 11:50 PM
satans csex's Avatar
satans csex
http://www.westcoastcorvette.com/p-4...-bolt-kit.aspx
Just buy this $ 50 part and if you cant install it ask me for instructions
Old Jun 1, 2008 | 12:42 AM
BlueFish81's Avatar
BlueFish81
I did cut the bushings all the way. I guess I will buy the bolts because this is getting really anoying. I am going to need to re align my car again ha? I just spent $125 for the alignment.
Thank you for the help.
Karn
Old Jun 1, 2008 | 12:18 PM
aTX427
Guest
Posts: n/a
it may be the metal hitting the fiberglass shock (which is a very bad thing). It will be WAY easier to install the WCC plastic cups and putting them over your existing bolts than removing the stockers for the replacement bolts.
Old Jun 1, 2008 | 12:37 PM
Braciole's Avatar
Braciole
St. Jude Donor '08
Arent the vettes low enough?? I hit the bottom on the driveway
as it is Stock I couldnt imagine any lower!!
Good luck
Mike
Old Jun 1, 2008 | 01:19 PM
VETTE IV's Avatar
VETTE IV
Old Jun 2, 2008 | 04:22 PM
PolishDude's Avatar
PolishDude
just buy the little plastic cups that go over the stock bolts, that will elimate your squeeking and still allow you to be lowered....i think they cost like 20 bucks
Old Jun 2, 2008 | 04:58 PM
carmos's Avatar
carmos
i get the squeaking too.but i did not cut the bushings.i just turned them as far as they would go.is this hurting\damaging the car?
Old Jun 2, 2008 | 05:26 PM
aTX427
Guest
Posts: n/a
no - it is probably the rubber cushion moving around.
Old Jun 2, 2008 | 06:21 PM
carmos's Avatar
carmos
john_sblendorio, thanks i was getting alittle worried.
Old Jun 2, 2008 | 07:30 PM
physiques's Avatar
physiques
Lowered mine about 2k miles ago with no alignment and no noticeable tire wear. Save your money and see if you notice any wear issues, if needed you can realign if you see the slightest of change.
Old Jun 2, 2008 | 08:02 PM
Racer86's Avatar
Racer86
So, you can see a half degree of camber or a a change of toe in/out. At $1k for a set of tires why not get it checked and aligned if needed
Old Jun 2, 2008 | 08:54 PM
iw172's Avatar
iw172
From: Retired early,everyday is Saturday...Hocking Hills Ohio
cheap insurance
Old Jun 2, 2008 | 09:41 PM
physiques's Avatar
physiques
If your tires started to wear differently than their norm you wouldn't notice. I'm confident if there is a change in my wear I will notice it with more then enough time to correct before having to go for new tires. Time will tell.
Old Jun 4, 2008 | 08:49 PM
BlueFish81's Avatar
BlueFish81
Hi Guys,
I got the bolts, can someone please give me instructions on how to replace the rear bolts?
Thank you.
Karn
Old Jun 4, 2008 | 08:55 PM
HAIL THI$'s Avatar
HAIL THI$
Don't save your money.
No matter what you need an alignment.
Good luck putting the new bolts in...it will look sweet!
To After lowering my C6 issue
Old Jun 4, 2008 | 10:48 PM
corvette dave's Avatar
corvette dave
Originally Posted by BlueFish81
Hi Guys,
Thank you.
Karn
I see this same question so often on here.
How about asking the vendor who sold you the bolts how to install them? Not trying to beat up on you but I wonder why so many products come without instructions. Did you get any instructions?
Do a search on the topic. Should be some good info.
You will have to disassemble some of the rear suspension to replace the bolts.
If you keep the ride height the same as it is now or close then I wouldn't worry about having the car aligned again.
Old Jun 5, 2008 | 11:26 PM
BlueFish81's Avatar
BlueFish81
There are no instructions. And as far as contacting the vendor goes I never even thought about that. I mean that is the exact point of being a member of a forum so you can share your experience / knowledge with people that is why I ask the guys here.
Thanks for the input.
Karn
Old Jun 5, 2008 | 11:41 PM
corvette dave
Karn,
This might help:
http://forums.corvetteforum.com/show...lowering+bolts
