Performance Programmer????
Old Jun 2, 2008 | 06:51 PM
c64lucky's Avatar
c64lucky
Default Performance Programmer????
Has anyone used Hyper-Tech Performance programmer or one similar?
Does it void Factory Warranty if used? Any & all Comments appreciated.
C64Lucky
Old Jun 2, 2008 | 11:35 PM
Braciole's Avatar
Braciole
St. Jude Donor '08
Oh I forgot yes it will void the warranty
Remove it when going to the dealer
Mike
Old Jun 2, 2008 | 11:36 PM
HawaiiC6's Avatar
HawaiiC6
Have not heard anyone in the C6 Tech or Tune section use the HyperTech tuner.
Most use the HP Tuners and the Predator tuners. I used the Predator as I wanted a tuner which would save the factory tune just in case I needed to do warranty work. I could download the factory tune back into the ECU.
Old Jun 3, 2008 | 01:09 PM
c64lucky's Avatar
c64lucky
I'll check those out.
Is there a noticeable difference in performance? Did you measure the difference(Dyno)? How much?
Thanks,
C64Lucky
To Performance Programmer????
