MN6 Trans Fluid Question
and I know this has been gone over before but I cant seem to find the right answer
I need to change my 2005 C6 Z51 MN6 Transmission fluid - first timer
Reading up on Amsoil, there seems to be two options.
AMSOIL ATF (stock code ATFQT)
AMSOIL Torque-Drive Synthetic Transmission Fluid (stock code ATD)
Question #1 - This appears to be Automatic Trans Fluid.
and...The Dexron appears TO be ATF
Is it common to put ATF in a manual trans?
Royal Purple Syncromax is option #2 and it does not appear to be ATF
http://www.royalpurple.com/manual-tr...ion-fluid.html
Question #2- It appears that the same fluid also used in the Differential? Is this correct?
Also- roughly what quantities should I buy?
Sincere Thanks
And no, trans fluid and diff fluid are not the same...not even close! The diff uses a much heavier oil, for mine I also used Amsoil, but again will have to check to see what type it was.
Common for modern manuals to use ATF. It's a good lube and has the qualities needed for modern synchros.
Thanks for the info.
I should have mentioned, the primary purpose for changing the fluid is that my trans is VERY stiff and notchy. Is the Amsoim ATF still be the best in this case?
Any idea of the amount of fluid I will need to do the Job?
Sincere thanks
I believe it takes 4+ qts if I recall correctly. Pretty easy to measure though as you cap it off once it starts to pour out of side fill hole.
Rear end I use 75W90 Royal Purple Gear max. I believe this is 2+ qts.
Sincere Thanks
Mike
Here's a couple links that may help:
http://forums.corvetteforum.com/show...ion+oil+change
http://forums.corvetteforum.com/show....php?t=1497063
Does help - and (probably) won't affect the warranty. Its better than Mobil 1 and whatever came from the factory.
Actually, I just went to all Red Line oils, as they now have a kit - engine, transmission and differential lube with additive, plus water wetter and fuel system cleaner. I'm a sucker for convenience.
