Dr Frankenstein Begins
Old Jun 14, 2008 | 09:31 PM
  #41
welcome2try's Avatar
welcome2try
From: Objects in your mirror are losing , Long Island, NY
St. Jude Donor '08
Originally Posted by Craigster05
Cameron can take a few runs, I'm really interested in it's potential.
Thanks for the confidence craig, I won't let you down.. Now lets find some sticky tires..
Lets borrow spins wheel and tire combo. MUHAHAHAHAHAHA..HAA.. That should do it. Only one thing, rev limiter must be adjusted to 6,900 rpms for optimum shift points
Old Jun 15, 2008 | 08:27 AM
  #42
mvcrash's Avatar
mvcrash
Originally Posted by welcome2try
Give me heads up, I might invite a bunch of fellow C6 buds if it is ok with you, if not please let me know.
We only allow about 24 cars for obvious reasons. I know I can get you and Craig in, let me see how many more are going to come on that day.
What's the date, Jeff? And you are mandatory for our dinner.
Dinner is fine anytime with you, name the place and time. I think it is the week after July 4th. I'm thinking the 10th is what I was told, I'll let you know. If you car runs as good as I think it will, I will ask someone you know to do it to my car also. I'd like to see what an Auto with your mods would do (minus the gear, I'm not changing the gear). I'd love to get my car into the 11's with the mild manners for the road you speak of.
Jeff
Old Jun 15, 2008 | 08:36 AM
  #43
Craigster05's Avatar
Craigster05
St. Jude Donor '07-'08-'09-'11-'12
Happy Father's Day, Jeff!
And of course, to all the other guys reading this!
Im trying to set up dinner either Thurs or Friday night this week. Ill call you and let you know.
My setup would be killer on your car, 11's for sure with your gears.
Old Jun 15, 2008 | 08:55 AM
  #44
mvcrash's Avatar
mvcrash
During the week, if you could make it like 7-730PM would be much easier to get out by you.
Old Jun 15, 2008 | 10:26 AM
  #45
Joe_G's Avatar
Joe_G
St. Jude Donor '08
Hey Craig, when you dyno, try to get the .drf dyno files from the dyno's computer. You can download the Dynojet software free and use it to print the dyno sheets or post them to the web or importantly compare your runs to previous runs or buddies' runs. GTODoug showed me how to do this, it's easy software to use, I can show you if you like.
I'd like to overlay your dyno run to mine to see where the gains are, as you know I'm thinking of following in your footsteps.
Old Jun 15, 2008 | 10:52 AM
  #46
Craigster05
No problem, Joe. I'll have some videos for you in a day or two...
Old Jun 15, 2008 | 12:48 PM
  #47
SpinMonster's Avatar
SpinMonster
Hey spin, tires and traction are a given when I made the 10'7 10'8 claim. That being said, I would get it in the 10's with any sticky tire combo guaranteed..
Actually what i am not saying is more important. While a car that is in fact capable of a ten second run will run 11's with a bad driver. The real point is that it looks like a brag when you type things like that before doing it. I dont know how you would run at a track since you havent done a 10 sec run. In a way i am jumping the gun and typing it before someone else does. I have learned that there are a lot of people who enjoy tearing a person down in that way on this forum. If your point is to say you're a great driver, its a brag and you should pass.
Talking about SOTP performance means nothing to people. We are in an envirnment where a car that dynos 5HP less has to be the slower car because area under the car is not well understood. If this car comes off the dyno with 467rwhp but did 400rwtq at 3800rpm's people will shrug their shoulders not caring since countless H/C cars that dyno 480 have only 360rwtq at 3800rpm to them have to be faster and they arent. 13HP at peak doesnt overtake a 40rwtq improvement in the midband's power. Still, peak dyno numbers sell H/C packages which I dont car about. The less I have to install for free the better. This car has 4.10's and will dyno 12+ less at the wheels due to the gears. That alone isnt welll understood and if the final dyno is 462rwhp (my guess by the way-and it comes with a slight lope but smooth idle and driveability) at peak it wont look as good to them. They will think,"Big deal 462rwhp." The car would of course then make 475rwhp with 3.42's. OK better but they saw that before too. The low end TQ however makes a serious difference btu then there are self proclaimed experts that insist the low end doesnt mean anything in the 1/4 which isnt true but opinions will persist. Then there is the street scene where countless dyno queens learn the hard way that a car spends 98% of its time under 5500 and roll-ons prove time and time again that area under the curve makes the faster car. I recall a certain local Z06 with 550rwhp ran a medium cam with bumped compression Z06 with 508rwhp. The 550rwhp guy lost over and over from a roll-on and from a dig.
Therein lies the differences in this package. The medium size cam will beat a peak overcammed car in a roll-on while maintaining the perfect street manners sought after by guys that bought a corvette because they didnt want a rough running 1970 Nova with a lopey cam. The cars running in the really high 400's that dyno between 475-490 use cams that are 233 or 234 duration. This package maximizes the low end with compression which you cant do with a big cam because there isnt enough room even with fly-cutting. When DTE Powertrain did a H/C package with these heads and a 224 cam producing over 470rwhp, I didnt se the point of trying to make a high HP over cammed car with a dip in the low end power between 3k and 4k. I thouught the area under the curve they acheived was far better than a peaky cam making 360rwtq in that range. The vast majority of guys would give up the peak few HP for that kind of midband and perfect manners. Phl stated the car idled and drove just like stock and thats when I knew I wasnt going over 230 for a cam with these heads. The power was in the heads themselves and you didnt need to overcam to get it.
Old Jun 15, 2008 | 01:06 PM
  #48
SpinMonster
With me driving, it may be a 15 second car... And yes, Im looking forward to a meet in NJ with our buds. Come on guys, lets do it in the next few weeks.
Craig, face it.....for a 3rd gear only run-up, we are the kings.
Old Jun 15, 2008 | 01:09 PM
  #49
SpinMonster
Can we get some miles on it first?
Old Jun 15, 2008 | 01:18 PM
  #50
welcome2try
St. Jude Donor '08
They will tear me down if I don't . But imagine if I do .
I think I would like to see what my own can do with street tires or sticky ones .
Old Jun 15, 2008 | 02:40 PM
  #51
k0bun's Avatar
k0bun
From: NJ..."the way I saw it, everyone takes a beating sometimes."
Uh oh Cam. You're talking a big game, with as relentless and unforgiving as this group is, you better back it up. Ahh what am I saying? According to you, you beat just about everything that rolls up on ya.
Old Jun 15, 2008 | 03:20 PM
  #52
LS1LT1's Avatar
LS1LT1
True, and some of us have a REALLY good memory too, even if these passes don't take place until the fall, I will remember these posts.
Old Jun 15, 2008 | 03:23 PM
  #53
Tony B4's Avatar
Tony B4
St. Jude Donor '08
I will be watching and waiting....
Old Jun 15, 2008 | 05:36 PM
  #54
SpinMonster
Is this where we talk smack to Cam?
Old Jun 15, 2008 | 05:37 PM
  #55
k0bun's Avatar
k0bun
And then some
Old Jun 15, 2008 | 10:57 PM
  #56
welcome2try
St. Jude Donor '08
I know some of you guys on the forum for a while and for most have met in person, for the exception of a few like (LS1LT1, " Kobun AKA Frankie.")
I feel pretty much at ease when I post here, since I know you guys for the most part. Please don't take offense, when I open my big mouth and claim to be the best driver on this side of earth It was presented mostly as a compliment to Craigs fantastic new ride, and not to promote my own agenda. Thanks guys for all the valuable tech info you bring to the forum, you know who you are.
Old Jun 18, 2008 | 04:27 PM
  #57
mvcrash's Avatar
mvcrash
July 9th, Island Raceway, $100.00 for the day, test and tune. If your interested PM.
Jeff
To Dr Frankenstein Begins
Old Jun 18, 2008 | 07:21 PM
  #58
NYC6's Avatar
NYC6
Jeff
Where is Island Raceway?
Old Jun 19, 2008 | 04:43 PM
  #59
LSCHLEM's Avatar
LSCHLEM
Island N.J. I could be wrong but I understand The Strip has been closed for twenty years or so. Most are going to ATCO for test and Tune.
Old Jun 19, 2008 | 04:51 PM
  #60
LSCHLEM's Avatar
LSCHLEM
Default Sorry
Sorryi WAS ACCIDENTLY REFERING TO POCONO DRAG LODGE I used to race at island in the 70's. Dont hear too much about it anymore.
