Rail covers
Old Jun 10, 2008 | 12:46 AM
rwarhol's Avatar
rwarhol
Default Rail covers
What is the easy way to take off the left side fuel rail cover,with out scratching the new paint.
Old Jun 10, 2008 | 12:58 AM
lockman's Avatar
lockman
put paniters tape around the opening where the fuel line goes I would say at least 3 layers to be safe and take your time with it
Old Jun 10, 2008 | 01:00 AM
rwarhol's Avatar
rwarhol
Thanks, good idea
Old Jun 10, 2008 | 10:04 AM
danl72's Avatar
danl72
Old Jun 10, 2008 | 12:17 PM
vettl83's Avatar
vettl83
Never thought of that, I just disconnected the fuel line.
Old Jun 10, 2008 | 12:36 PM
rwarhol's Avatar
rwarhol
Is the fuel line under preasure .
Old Jun 10, 2008 | 01:25 PM
pwoolford's Avatar
pwoolford
St. Jude Donor '08
I've had mine off/on a couple times and if you recently shut the car down (within 4-6 hours) there may be a little pressure. Mine has always sat overnight and there was never any pressure. Of course I did wrap rags around the line first just to be safe.
Old Jun 10, 2008 | 02:14 PM
vettl83's Avatar
vettl83
Roger that! I just remove the gas cap, put a rag under the Shrader valve on the fuel rail and release the pressure. You will need a 3/8" fuel line removal tool to disconnect the fuel line. You can get a whole set of em at Auto Zone or such for a couple of dollars.
Old Jun 10, 2008 | 10:54 PM
rwarhol's Avatar
rwarhol
Take the fuel line loose sound like the way,thanks all you guys .
Old Jun 10, 2008 | 11:05 PM
oldmansan's Avatar
oldmansan
St. Jude Donor '09
I wrapped plastic wrap around the hose and it worked fine. No scratches.
San
Old Jun 11, 2008 | 07:10 AM
timd38's Avatar
timd38
That process works great! Also. do it with the engine warm, the plastic is more pliable.
Old Jun 11, 2008 | 07:13 AM
patton's Avatar
patton
St. Jude Donor '09
yepper
To Rail covers
