MN6 making bad noises
Old Jun 11, 2008 | 10:37 PM
Theels12588's Avatar
Theels12588
Default MN6 making bad noises
When I am in gear at slower speeds (0-15mph) and take a turn, there is a wierd grinding sound and vibration. Never happens when I'm in a straight line, and it does not happen in the same situations when I'm in neutral and/or when the clutch is out.
I feel like the more I have to turn the steering wheel, the more I experience the grinding/vibration. Also if I'm going really slow and turning in 1st gear in a parking lot for example, the noise corresponds to the lurching or uneasiness of letting off the gas at a really low speed.
It can't be a steering issue because there is absolutely no sound when the clutch is out during a turn, or when I'm in neutral in a turn. So it must be a transmission problem, but it only occurs when I'm turning.
Any ideas as to what may be causing this? It's a pretty nasty sound.
Old Jun 11, 2008 | 10:43 PM
Braciole's Avatar
Braciole
St. Jude Donor '08
07 C6 ??? You got me.
You should still be under warranty.
I have an 07 C6 Z51 MN6
I never heard such a thing it doesnt sound promising.
What is done to your car??? Stock??
or list the mods..
How many miles??
Mike
Old Jun 11, 2008 | 10:56 PM
JTS97Z28's Avatar
JTS97Z28
Hummmm I was gonna say sounds like rear end gear chatter/binding, but you just mentioned it does not happen when the clutch is in so that would eliminate anything from the rear end since that is spinning regardless of what the clutch is doing...hummm wish I could help
Old Jun 11, 2008 | 11:21 PM
Braciole's Avatar
Braciole
St. Jude Donor '08
YEP we need more info!!
Mike
Old Jun 13, 2008 | 12:56 PM
Theels12588
It's an '07 c6 with just under 9,000 miles. All running-gear is stock...
Thanks for the help
To MN6 making bad noises
