ls3 cam install - do i need anything else
Old Jun 13, 2008 | 10:34 AM
beefcake's Avatar
beefcake
Default ls3 cam install - do i need anything else
trying to make sure i've got everything for my guy
i ordered everything myself, i got the full lg package, bolts, gaskets etc..
i've got the cam, springs and pushrods coming from livernois.
i just found out that i guess i need a timing chain as well, is there anything else i'm gonna need so i don't get stuck down for a while
thanks in advance
Old Jun 13, 2008 | 11:09 AM
Chevy Enforcer's Avatar
Chevy Enforcer
You don't need a timing chain at all what you need is a z06 ls7 cam gear.
cheers
Old Jun 13, 2008 | 11:59 AM
beefcake's Avatar
beefcake
livernois told me i needed a timing chain, said it comes with the new gear, like $99
Old Jun 13, 2008 | 12:03 PM
beefcake's Avatar
beefcake
actually i just spoke to a tech guy there, what he said was the timing chain wasn't need, that the cam gear was, but that they recommend the chain as it's a stronger unit
like i said, i don't know squat, i just wanna go fast like ricky bobby lol
maybe i should stick to mustangs lol
Old Jun 13, 2008 | 12:30 PM
Craigster05's Avatar
Craigster05
St. Jude Donor '07-'08-'09-'11-'12
Get the chain, you'll be happy that you did. I just did a head/cam swap on my LS2 with 10K miles, and you could see there was already some stretching in the OEM chain. I used the IWIN Rollermaster from Scoggins - $49.99 - very cheap insurance. Make sure you also have the crank seal and 2 balancer bolts. One to mount torque the balancer, then remove it and use the 2nd one as the permanent bolt. At $14.00, more cheap insurance.
You may want to add an underdrive pulley since you have to pull the balancer anyway. Forum Vendor ByunSpeed has the Powerbond UD, belt and balancer bolt for $200 shipped.
To ls3 cam install - do i need anything else
