Horn stuck-cause?
Old Jun 13, 2008 | 07:33 PM
redline_ken's Avatar
redline_ken
Default Horn stuck-cause?
It was HOT today and as soon as I opened the door, the horn started blasting and wouldn't stop until I pulled the fuse under the hood. I swapped fuses with the same number (for the high beams) and it still blasted. The key fob wouldn't stop it either. I'm thinking the horn button is guilty due to the heat??? Luckily I've got the GMPP extended warranty on it. Anyone have this problem and a fix?
