Hey guys, I need to figure out a problem with my car. I have a list of things i learned about the engine drag control feature, please make a comment if you know for a fact that I am wrong. (Please dont post about how you never see it, especially automatic drivers since they don't really get into a high vacuum high rpm situation).
#1 Using JUST the speed sensors, the computer reads the speed differential between the front and rear wheels to determine if engine drag control is needed. (yaw sensors not part of the process?)
#2 Engine drag control only works in normal mode, doesn't work with TC off, Comp mode, TC/AH off mode?
#3 Engine drag control feature controls the amount of engine braking by changing timing on the engine, it doesn't apply brakes? Matter of fact, it applies gas to compensate?
That's as far as I know, please add comment if you know something about the feature that I didn't list here.
From: Greater Detroit Metro MI, when I'm not travelling.
Here is a patent for the system.
http://www.google.com/patents?id=9kM...BAJ&dq=6952638
Looks like it detects excessive engine braking in much the same way traction control does; by looking at the ABS signal of the rear wheels in relation to the front ones and deducing wheel slip from a speed difference... It will limit engine braking by decreasing the rate the throttle body closes at or even holding it partially open.
Do you have any issues with TC?
Got any mods?? I don't know anything about your setup but I am going to guess you have aftermarket tires of a different size from stock. That being the case your ECU thinks your tires are constantly spinning... You can tune it out if the difference isn't very large... I've heard 3% on this forum. Hopefully tuners can chime in and give you a better answer?
On this Youtube Video engine drag control comes on when the driver lifts at circa 190MPH...
I have a RF speed sensor short somewhere in the system that is intermittent. They replaced the sensor and hub, but it is still throwing the RF speed sensor code. Although I dont get the code immediately, but I can see the car is acting up due to my engine drag control being active almost all the time. I just want to make sure it is only adding gas and not applying brakes. Also I didnt know the system doesn't work with the TC off and in comp mode and the whole thing off
In the tune you can adjust the rear tire diameter. This will make your speedometer and odometer read correctly. This won't change when or if you get the engine drag control enaging. Been there, tried that. It's not a big deal, I just ignore it.
Kind of reverse Traction Control? Uses the Drive By Wire computer to keep the throttle blade open so the rear wheels don't lock up? Remember, your right foot doesn't control the throttle opening, it makes a suggestion to the computer and the computer decides how far to open or close the throttle. Open throttle means less engine braking.
I wish one of the tuners could log what happens when the "Drag Control Active" happens.
Does it? I wouldn't know (never seen the message on my car -Ops! You said not to tell you that- ).
Exactly. Some people actually report that they can feel the car lurch forward slightly when it comes on because the ECU is giving it a little bit too much throttle.
Assuming this does not cause an over speed of the engine, the ECM adds throttle to eliminate rear wheel skid.
However, a skilled driver will always match engine rpms to driveshaft speed on down shifts.
I suspect the purpose of engine drag control is to assist AH in preventing lift-throttle oversteer -- which has to be the #1 cause of high-speed spinouts. It has to work by getting back on the throttle -- otherwise, we're just talking about another facet of AH.
Funny thing is that I didnt see it when the TC/AH is off. Heck, it didnt go on even if when comp mode is on. So I am not sure if that is the case or not.
