Error Codes
Old Jun 17, 2008 | 12:00 PM
SLW2525's Avatar
SLW2525
Navigator
Default Error Codes
Do the computer generated (internal) error codes get deleted when the battery dies?? (completely drained.)
Old Jun 17, 2008 | 01:03 PM
patton's Avatar
patton
St. Jude Donor '09
a batt disconnect usualy deletes codes. a drained batt may keep enuf voltage to keep alive some codes. a hard code will return always
Old Jun 17, 2008 | 01:06 PM
danl72's Avatar
danl72
Old Jun 17, 2008 | 01:25 PM
Wayne O's Avatar
Wayne O
CF Senior Member
I believe, priority DTC's will be retained or freeze-framed.
Old Jun 17, 2008 | 03:52 PM
calemasters's Avatar
calemasters
Codes remain in history. They can be deleted with the Tech 2.
If an intermittent (not current) condition caused the MIL to illuminate, loss of +12v can reset the MIL.
Old Jun 17, 2008 | 04:22 PM
NEV3R L8's Avatar
NEV3R L8
Did you have a code pop up? You can take it by an Advanced Auto Part store or similar and borrow a OBDII 2 reader and check and clear the code.
To Error Codes
