Fastest C6 (but with caveats)
Old Jun 25, 2008 | 12:07 AM
catpat8000's Avatar
catpat8000
Default Fastest C6 (but with caveats)
I'm interested in seeing how fast I can get my C6 to go. However, I want to put one single restriction on what mods are allowed: no visible mods.
Basically, I am interested in seeing how fast I can make my C6 without any visible mods at all. This means headers, CAI, etc are all off the table.
What are the community's thoughts?
So far I've added gears, a 160 tstat, and a tune to my LS3 and this got me to 414 rwhp.
Clearly some sort of cam is the next option. Any other suggestions? Head porting is not inconceivable but on the LS3 with stock intake and exhaust, I doubt it's worthwhile.
Pat
Old Jun 25, 2008 | 12:32 AM
Mr.Big's Avatar
Mr.Big
Hidden "Dry" shot...
Old Jun 25, 2008 | 12:57 AM
BlueFish81's Avatar
BlueFish81
1. Hollow out your cats. That with another tune will give you some more power.
2. Add NPP which is a factory GM muffler if you do not already have it. 3. Change your run flats to non run flats which will reduce some rotational mass.
4. Change your flywheel to lighter one.
5. If you get rid of your cats you can use race gas to put out few more ponies with a race gas tune.
I think this is it.
Karn
Old Jun 25, 2008 | 01:51 AM
ProgGod's Avatar
ProgGod
What are your goals, drag racing, daily driving, road course, etc? What is your budget?
Old Jun 25, 2008 | 02:05 AM
bent's Avatar
bent
stock appearing will fool most people......changing the cam is a dead giveaway FWIW.....
Old Jun 25, 2008 | 02:18 AM
catpat8000's Avatar
catpat8000
Weekend driver + some drag racing.
Instead of asking about my budget, why don't you propose something?
Pat
Old Jun 25, 2008 | 02:20 AM
catpat8000's Avatar
catpat8000
Not clear. There are several cams out there advertized as "stealth" cams including custom grinds from knowledgable tuners.
Pat
Old Jun 25, 2008 | 03:33 AM
HOXXOH's Avatar
HOXXOH
Pat
I'm not sure of your reason to not have visible mods. Warranty? Claiming it's stock for street grudge or money racing? Or?
But if your budget is limitless and everything MUST be internal, do a bore and stroke to the limit for starters. Include a cam, titanium rods, lighter pistons with more compression, some serious head work, lighter/larger valves and springs, bigger injectors. Too bad though that all the stuff you want to do will be restricted by the ability to breathe properly, which is the single most thing the ls3 needs.
Then the greatest difficulty with all the extra power is getting it to the ground with the stock tires.
If you're trying to hide mods from your wife, she probably already knows.
Old Jun 25, 2008 | 04:53 AM
LS1LT1's Avatar
LS1LT1
I think this is it.
All of the above but there are a few more...
Port your intake manifold and throttle body.
Better clutch (while you're already in there doing the above mentioned flywheel) if you're a manual...higher stall torque converter if you're an automatic (I assume from the horsepower numbers that it's a manual)
I was going to say gears but I see you already have them
Lighter brakes
You could also pull some sound deadening/carpet padding out
Old Jun 25, 2008 | 10:36 AM
'06 Quicksilver Z06's Avatar
'06 Quicksilver Z06
Pat
Tune to run mixture of E85 and premium gasoline.
http://youtube.com/watch?v=hjdPtcBXlgw
I don't believe anyone can get more stealth than that. This might be hands down the most stealth method of improving your car's performance if you are not too concerned about the possible "long term" effects of it on your fuel system components.
In the long run though, as long as you aren't running it all the time, every tank, its probably not carrying considerably more risk than some of the other stuff you could do.
Old Jun 25, 2008 | 10:40 AM
mkr3686's Avatar
mkr3686
Hey Pat,
I actually suggested this on another thread and I think its a really neat idea. I wish you the very best of luck and can't wait for the results.
As far as Cam's, check out the Cartek website as they have a couple of smaller semi-stealthy cams that would make decent power.
Are better tires an option as long as they are on the same rims? R888's might help you hook that power up a lot better and would look pretty stock other than a different tread.
Old Jun 25, 2008 | 11:30 AM
Ragtop 99's Avatar
Ragtop 99
Thinner head gasket and mild clean up of the LS3 heads will gain more power. Yes, there are cams that are very hard to detect, especially using stock manifolds (absorb sound) and an 850 rpm idle to eliminate lope. The key is stay zero overlap or less. I'd spec the cam and not buy off the shelf and do it as a package with a compression bump.
a full Z06 exhaust system looks like factory and will add some power. An underdrive pulley, depending upon the brand, requires a pretty good eye to spot.
Old Jun 25, 2008 | 03:49 PM
Max@Cartek's Avatar
Max@Cartek
I would do a mild cam, port the intake, port the TB, and maybe extrude hone the manifolds. Just some ideas.
Give us a call if you have any questions. It sounds like a fun project.
Max
908.317.4496
Old Jun 25, 2008 | 06:46 PM
Vito.A's Avatar
Vito.A
If this is truely open ended funding, I would max bore and stroke the short block (or use the LS7 4.125" bore block). Use a Callies Magnum lightweight crank and Carrillo or Oliver light weight steel rods with JE forged pistons with coated skirts. Tapered tool steel wrist pins. Have the heads fully ported and install Manley titanium valves (both intake and exhaust), dual springs, titanium retainers, a good aftermarket shaft rocker system. Also port the stock intake manifold and throttle body. Cam selection should involve dyno work by a talented individual or shop to maximize the combination through stock exhaust manifolds. I agree with the recommendation to hollow out the stock cats and free up the exhaust by extrude honing the cast iron exhaust manifolds.
Consider 4.10 gears and some good drag radials and lighten the car as much as possible.
Old Jun 25, 2008 | 11:55 PM
SoldSyclone's Avatar
SoldSyclone
"Moneymaker" N20 system drives/sounds 100% stock then add 150rwhp and 200rwtq with a flip of the switch
Old Jun 26, 2008 | 12:10 AM
catpat8000's Avatar
catpat8000
Max
908.317.4496
From everything I've read, you guys seem like a great shop! If I lived within 2000 miles of you, I'd be there.
Pat
Old Jun 26, 2008 | 10:17 AM
Max@Cartek's Avatar
Max@Cartek
Pat
Thanks for the compliment, we appreciate it
Max
To Fastest C6 (but with caveats)
Old Jun 26, 2008 | 10:35 AM
kwiktsi's Avatar
kwiktsi
If money is no object (or of very little), I would go the stroker/ported heads/sleeper cam/Z06 manifolds and exhaust route. If you wanted nitrous, you can add a hidden kit as well . If you are on a budget- maybe the Z06 exhaust setup with nitrous.
Old Jun 26, 2008 | 11:54 AM
PowerLabs's Avatar
PowerLabs
From: Greater Detroit Metro MI, when I'm not travelling.
Pull the motor out, replace it with a larger engine, then put the stock engine covers on... Stealthy unless someone was to read the numbers on the block..
Old Jun 26, 2008 | 12:20 PM
TorontoC6's Avatar
TorontoC6
I don't get it. Who are you trying to fool? You can build a powerhouse engine that appears (visibly) stock but it won't sound like stock. Even headers will change the sound. Are they just going to look at your engine but not hear it run? What's the point?
