A6 didn't downshift
Old Jul 7, 2008 | 02:57 PM
NXTFAZE's Avatar
NXTFAZE
Default A6 didn't downshift
Long story short, took the car up to Ohio from NC for the 4th of July. I was in Ohio and needed to use the cruise control because of all the cops. I went to pass another car while I was in S mode (paddle shift not activated) with the cruise control on and the car would not down shift like it normally did when I floored it.
I waited a couple of seconds and tried it again...nothing...it stayed in sixth gear.
Waited a couple more seconds and floored it again and it downshifted that time. It has not done this before and have not had it reoccur with me since.
I also let my brother drive the car and it happened to him, he was going about 35 mph and punched it, it did not down shift....
Anyone ever have this happen? Something I should take to the dealer to check out?
Thanks for any input.
Old Jul 7, 2008 | 04:44 PM
NXTFAZE's Avatar
NXTFAZE
Anyone?
Old Jul 8, 2008 | 08:55 AM
NXTFAZE's Avatar
NXTFAZE
bump....
Old Jul 8, 2008 | 09:29 AM
CodyC6's Avatar
CodyC6
Nope, haven't had that happen.
Matter of fact, cruising at lower speeds like the 35 you mentioned, I can just tap the throttle and downshift the trans with my foot. For example, I'm going up a hill, and I want a lower gear, I just tap the gas and it will downshift to a lower gear right away.
Unless traction control is causing yours not to downshift when you floor it, you may need to have that looked at. Either a sensor is holding it up, or something may be in need of adjustment.
What happens in "D"? What happens with traction controll turned off? Just some thoughts.
Old Jul 8, 2008 | 10:23 AM
svoshop's Avatar
svoshop
You may have a throttle position sensor not reading correctly. Not sure if our cars actually have one, based on the electronic throttle, however, what ever is used to send the signal to the ECM may be at fault.
Mike
Old Jul 8, 2008 | 11:42 AM
NXTFAZE's Avatar
NXTFAZE
Thanks for the input.... It only happened to me once, so I'm not concerned yet. Normally the car shifts immediately to a lower gear at part throttle and drops two gears if I mash the throttle on the highway.
I thought it might be because of the cruise control, but was not able to duplicate it.....???
Old Jul 8, 2008 | 11:49 AM
HawaiiC6's Avatar
HawaiiC6
If your HUD showed 6th gear then you were in S manual mode, the car will not downshift, you must manually downshift to accelerate. Try taking your car out and leave the car in D mode then hit the throttle it should go two gears down and really plant you back in your seat. If it doesn't then you do have a problem with the trans module.
Keep us updated on this as I have not had a problem with the downshifting.
Old Jul 8, 2008 | 01:24 PM
NXTFAZE's Avatar
NXTFAZE
Thanks for your input, but re-read my initial post. I was in S mode AND the paddles were NOT activiated.
Old Jul 8, 2008 | 02:08 PM
jimmie jam's Avatar
jimmie jam
mine did something very similar at 1,000 miles about a year ago. now i'm at 2,600 and have never experienced the problem again. just a bmc fart i guess.
Old Jul 8, 2008 | 02:58 PM
NXTFAZE's Avatar
NXTFAZE
Originally Posted by jimmie jam
mine did something very similar at about 1,000 miles about a year ago. now i'm at 2,600 and have never experienced the problem again. just a bmc fart i guess.
Thanks everyone for their input... My car isn't a daily, so I'll have to wait to see if it happens again.
I thought it might have something to do with the long trip to Ohio....8 hours without any time to cool down???
Old Jul 8, 2008 | 06:05 PM
JohnNC's Avatar
JohnNC
Hey Marko,
Sorry to hear that your having problems.
Never had your stated problems when
I owned your car.
Hopefully it clears up??
John
Old Jul 8, 2008 | 07:16 PM
danl72's Avatar
danl72
Sorry to hear about your problem. I have not had this happen.
Old Jul 8, 2008 | 07:28 PM
Daytona Bob's Avatar
Daytona Bob
St. Jude Donor '09 & '12, '14
My situation is as follows.
Cruisin along around 45mph with TC/AH on.
Push pedal to WOT. Car gives the minor auto (normal) Hesitation where you are like "oh crap here it comes"
I let the accelerator pedal rise a little to avoid a major shift shock but still want to GO!
Car fails to downshift and I hear an Engine noise (Like the power is being wasted away) I'm sitting there NOT GOING ANYWHERE
Let off Gas
Do it again to WOT (works fine)
I wonder if i fooled the A6 or TCS totally shut me down (no power) (Just engine noise)
In my C5 - the traction control system would still allow acceleration even i was losing traction (just reduced)
This was definitely a YOUR NOT GOING ANYWHERE feeling.
07 A6...
To A6 didn't downshift
