Change Clutch Fluid ???
Old Jul 18, 2008 | 12:11 AM
NTMD8R's Avatar
NTMD8R
Default Change Clutch Fluid ???
I have heard from a couple of people, that if you will be driving your C6 "Spiritedly", it might be an idea to change the clutch fluid to something a little more "Robust"... like Dot5.
Can anyone confirm (or not) that this would be a good thing to do ?
Old Jul 18, 2008 | 12:14 AM
rws.1's Avatar
rws.1
DOT 4 is fine.
Just keep an eye on the color in the reservour, when it starts going dark, suck it out with a syringe and refill with fresh fluid.
Old Jul 18, 2008 | 06:03 AM
patton's Avatar
patton
St. Jude Donor '09
do not use 5
Old Jul 18, 2008 | 06:17 AM
///DarkSide\\\'s Avatar
///DarkSide\\\
St. Jude Donor '12 thru '26
Originally Posted by patton
do not use 5
DOT 4 only
Old Jul 18, 2008 | 11:38 PM
cencalc6's Avatar
cencalc6
I recently used DOT 3 is this bad
Old Jul 19, 2008 | 01:27 AM
99FewteRC5's Avatar
99FewteRC5
Not bad, but not good. You didnt damage anything but you lowered the boiling point. Just suck it out and fill with dot 4. I dont thing Dot 5(silicion base) is not compatible with dot 3 or 4.
Old Jul 19, 2008 | 12:00 PM
glennxx1's Avatar
glennxx1
so in my c5, i should replace my clutch fluid with dot 4 when i replace it? same with the brake fluid?
Old Jul 19, 2008 | 12:37 PM
Wayne O's Avatar
Wayne O
CF Senior Member
Originally Posted by rws.1
DOT 4 is fine.
You have to do a bit more than just replace the fluid in the reservoir. Search for Ranger's DIY instructions or look to Ranger's website.
http://www.rangeracceleration.com/Clutch_Care.html
do not use 5
Don't use DOT 5 under any circumstance.
Old Jul 20, 2008 | 10:47 AM
cencalc6's Avatar
cencalc6
thanks
To Change Clutch Fluid ???
