Home Brew z51?
Old Jul 21, 2008 | 10:15 AM
Dirt Rider's Avatar
Dirt Rider
Default Home Brew z51?
I feel like I'm getting too hung up on finding a used 08 with z51? I read a post here where someone made the comment that you could get better that z51 performance via aftermarket for the same or less? Any thoughts or experience would be appreciated.
Old Jul 21, 2008 | 10:46 AM
NYC6's Avatar
NYC6
For the money the Z51 package cant be beat. Better brakes,additional cooling,better tires,gears,better handling shocks and sways cant be reproduced aftermarket for the price GM offers it.
Old Jul 21, 2008 | 10:49 AM
UNKNOWN's Avatar
UNKNOWN
Banned Scam/Spammer
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15-'16-'17
wait til next year to buy, there will be plenty
Old Jul 21, 2008 | 10:50 AM
rovers2000's Avatar
rovers2000
Gene Gully at gmpartswarhouse offers all the Z51 parts to change a base car to a Z51 or even better you could change a base to the ride of a z06 if you wanted to. The base and z51 have the same power train.
Z51 has:
bigger cross drilled rotors
hevier front spring, little bit lighter rear spring and stiffer shocks
Bigger front and rear swaybars
Steering system cooler
So it is real easy to set up the base cars handling and braking to match a Z51, thats what i did to my car.
Old Jul 21, 2008 | 11:37 AM
danl72's Avatar
danl72
Originally Posted by NYC6
For the money the Z51 package cant be beat. Better brakes,additional cooling,better handling cant be reproduced aftermarket for the price GM offers it.
Old Jul 21, 2008 | 11:38 AM
danl72's Avatar
danl72
Might not even have to wait a year. Could be sooner.
Old Jul 21, 2008 | 03:36 PM
Dirt Rider's Avatar
Dirt Rider
Ya, I just hate to be the guy that takes the new hit on a NEW car. Love to find a dealio on an 08 used if possible. To me it sure seemed like the z51 package was a good deal for what you got, but I had to ask.
My first venture into the sports car world (as far as owning) and if it's anything like the way I go through motorcycles it won't be the last. We have a saying when guys get into (or back into) riding dirt bikes...you buy a bike, you buy another bike, then you buy the RIGHT bike. Only these are about 6 times the money. Really can't afford to buy the WRONG car.
Old Jul 21, 2008 | 06:25 PM
01SStoZo6's Avatar
01SStoZo6
I thought the z51s had different ratios in the tranny
Old Jul 21, 2008 | 07:20 PM
Leprkon's Avatar
Leprkon
aftermarket brake rotors- $415
brackets- $200
sways- $160
end links - $200
poly bushings - $30
edelbrock shocks - $400
result- better d/d and probably long-term quality than Z51, but still no oil cooler
tires- debateable- you'll buy alot more S/C's than runflats
Old Jul 21, 2008 | 07:25 PM
Stage IT's Avatar
Stage IT
Z51 has:
the real z51 will still be fatser because of the lower geared tranny drive both and you see the acceleration difference
Old Jul 21, 2008 | 07:36 PM
NYC6's Avatar
NYC6
brackets- $200
sways- $160
end links - $200
poly bushings - $30
Your at $1400 already not accounting additional coolers,gears and tires and labor. The Z51 package is about $1600. Not to mention the fact that a factory installed option package will be worth way more come resale time.
Old Jul 21, 2008 | 07:56 PM
AORoads's Avatar
AORoads
St. Jude Donor '15
"In honor of jpee"
it does, in the man trans. not the automatic which you can buy also with the Z51 option.
OP, keep looking and don't be afraid to travel some for a good car. in other words, don't limit yourself to 100 miles from hometown.
Old Jul 21, 2008 | 09:50 PM
Leprkon's Avatar
Leprkon
it can definitely be argued both ways. I would probably get a Z51 package now, but I'd still do the shocks, bushings, and end links.
you won't find this under a stock Z.
Old Jul 21, 2008 | 10:13 PM
A-Pex's Avatar
A-Pex
Alternately, the new ZR1 is using Magnetic Ride Control (albeit a likely much improved version from the F55).
Additionally, from the Corvette Quarterly article I just read the ZR1 version is a MUCH better suspension than the 2007 Z06 suspension.
I've got the F55 w/ Z51 sways installed and I LOVE it. That being said, I've never driven a stock Z51 to compare it to.
Lastly, I'd recommend staying away from drilled rotors as they tend to crack (or so the forum rumor has it), but slotted are very much improved over non-slotted.
Not sure if this helps or convolutes the issue, but there you have it.
Old Jul 21, 2008 | 11:17 PM
Dirt Rider's Avatar
Dirt Rider
Good stuff. Thanks for everyones input. Hadn't considered the gears...or should I say, I didn't realize there was a gearing difference.
I know I'll find one, just have to patient. Something I'm not very good at. Hell if I wait too long I won't want one anymore...and that's no fun at all!
Old Jul 22, 2008 | 12:38 AM
eurostyle's Avatar
eurostyle
I have a 2007 Z51 VY for sale in Cali.
Old Jul 22, 2008 | 09:37 AM
PowerLabs's Avatar
PowerLabs
From: Greater Detroit Metro MI, when I'm not travelling.
Z51 has:
You are missing out:
Lower gears for faster acceleration
Transmission cooler
Better tires (softer compound for more grip)
Resulting in 0.1 seconds faster sprint to 60mph and 0.02 higher skidpad rating.
Good luck getting those two done to your car for less than what the Z51 package costs
To Home Brew z51?
Old Jul 22, 2008 | 09:42 AM
PowerLabs's Avatar
PowerLabs
I will have to disagree with that: I drive my car harder than ANYONE I know (repeated stops from high speeds, slowing down from 180MPH+, etc) and all 4 of my rotors are worn down to where you can see a lip on them from 20 feet away and yet they don't have a single crack.
The only time cross drilled rotors crack is when you take the car to the track and overheat them. I will agree that for extended race track usage non cross drilled rotors may be better but that represents perhaps 0.1% of what the typical Corvette owner does with his car. For the remainder 99.9% the cross drilled rotors look better and provide more swept area and heat capacity for increased stopping power.
Old Jul 22, 2008 | 10:42 AM
AORoads's Avatar
AORoads
St. Jude Donor '15
"In honor of jpee"
More swept area? The rotors are larger in the Z51 vs. base, but holes don't increase the amount of actual, contact material, do they?
Old Jul 22, 2008 | 12:26 PM
Leprkon's Avatar
Leprkon
It's easy to get one or the other, but not both.
The tires, however, remain to be debated as "better". They cost alot more, make alot more noise, and last alot less.
I think either set-up would be on aftermarket by the first change-out. One driver would be out that cost well before the other. <shrug>
