Caliper Rebuild . . . Torque Specs?
Old Jul 25, 2008 | 01:26 AM
Jahan's Avatar
Jahan
Default Caliper Rebuild . . . Torque Specs?
I'm rebuilding my freshly powdercoated calipers . . . does anyone know the torque specs on the slide pin bolts?
Old Jul 25, 2008 | 01:45 AM
Silverspeed's Avatar
Silverspeed
St. Jude Donor '13, '15
Copied this from a thread I started a year ago. Poster said this came straight out of the 2007 Helms manual.
Brake Caliper Bleed Screw 106 lb in
Brake Caliper Guide Pin Bolt 23 lb ft
Brake Caliper Inlet Fitting Bolt 33 lb ft
Front Brake Caliper Mounting Bracket bolt 125 lb ft
Rear Brake Caliper Mounting Bracket bolt 125 lb ft
Here's a link to the thread, and by the way, I re-used my caliper bracket bolts. Service manual says not to.
http://forums.corvetteforum.com/show...er+bolt+torque
