P0106 Code
Old Aug 1, 2008 | 03:19 PM
Nightstalker Medic's Avatar
Nightstalker Medic
Default P0106 Code
This code is puzzling. I was getting the P0171 and P0174 codes too. After some research on the forum, I added some Turbo 108 Octane Booster to my tank and the P0171 and P0174 codes have disappeared for now. But I'm still getting the P0106 (map out of range) code. I have done the following to the car:
- Halltech C6, Venom CAI
- Kooks Headers (1-7/8)
- Kooks X-Pipe (3" - 2-1/2)
- Flow master Americasn Tunder Mufflers
- Pateriot Extreme .660 Springs
- Englandgreen Whiplash Cam
- Oil Can
- 160 Thermostat
- Car Tuned
- and a few other mods
I pulled everything back off and reinstalled them thinking I and checking for leaks. None. No burnt or melted wires. Did a leak-down test and it shows perfectly fine at 2%-3% across all cylinders hot. I've cleaned the MAF Sensor. Placed no oil on the CAI filter to mess up the MAF sensor connected to the CAI to the TB.
Other than the light being in PITA. The car drives great. Plenty of power after the car was tuned.
Is there something I'm missing here?
Thank You
Walter
Old Aug 1, 2008 | 09:25 PM
corvettedoctor's Avatar
corvettedoctor
Hi:
I would have the tune looked at again.
Sounds like some air caculations and a few other things need to be reworked.
Chris
Old Aug 1, 2008 | 10:01 PM
patton's Avatar
patton
St. Jude Donor '09
Originally Posted by corvettedoctor
Hi:
Chris
Old Aug 2, 2008 | 12:00 AM
Nightstalker Medic
I contacted my tuner late this evening and explained what was going on. He stated to bring it back in for another go over.
Thanks for the help!!!
To P0106 Code
