a6 shifting issue???
Old Aug 2, 2008 | 08:18 PM
vinsane112's Avatar
vinsane112
Default a6 shifting issue???
had the vette out today and while cruising in full auto sport mode it hit the throttle at about 25 mph. the car kicked down in first like i intended but instead of shifting hit the rev limiter. as soon as i back off the throttle the car shifted. i found a long empty road and tried to replicate this about 8 times but it only did it one more time---no issue in paddle shift mode though---any ideas or is it time for a trip to chevy??
Old Aug 2, 2008 | 09:18 PM
ILLUSHN's Avatar
ILLUSHN
I find that mine seems to stay in a gear longer than it should from time to time as well. Drive or Sport. No paddles. But I can't recreate it when I try. It just does it on its own.
Old Aug 2, 2008 | 11:57 PM
knkali's Avatar
knkali
I thought my car was the only one that did this but add me to the list too. It is weird. It does it here and there. Cant replicate on demand
Old Aug 3, 2008 | 12:19 AM
LS1LT1's Avatar
LS1LT1
Any chance that there was some wheelspin?
Spinning tires don't always make a screaching sound and that could definitely help increase the revs enough under hard throttle to tap the limiter.
Old Aug 3, 2008 | 12:57 AM
vinsane112's Avatar
vinsane112
thats what i figured it was
Old Aug 3, 2008 | 10:24 AM
knkali's Avatar
knkali
no spin because i can modulate the throttle a little while it is doing it so I dont think wheel spin is the culprit
Old Aug 3, 2008 | 09:51 PM
9192champs's Avatar
9192champs
Old Aug 3, 2008 | 10:25 PM
knkali's Avatar
knkali
wot goes to max rpm but say 3/4 throttle punches should shift at a lower rpm and it doesnt at times.
Old Aug 3, 2008 | 11:22 PM
vinsane112's Avatar
vinsane112
Originally Posted by 9192champs
I have a 2008 with the A6, and if I'm cruising around 30 mph or so and really punch it, the revs usually reach the red-line very quickly before it shifts... I just assumed this was normal. It isn't?
no thats totally normal---mine hit the rev limiter and bogged down before shifting when doing the same thing---ur fine
To a6 shifting issue???
