z51 sway bars
Old Aug 4, 2008 | 01:53 AM
alangordon's Avatar
alangordon
Default z51 sway bars
I Have An O8 A6 Corvette,i Am Thinging Of Changing Over To The Z51 Sway Bars,i Would Like To Know If Anyone Has Done This Modification To O8 Coupe And What I Can Expect As Far As Ride And Handling. Thanks In Advance.
Old Aug 4, 2008 | 03:23 AM
keyplyr's Avatar
keyplyr
I added Z51 sway bars to my base suspension '05 and it improved the handling. An '08 would benefit the same.
Might also wish to consider upgrading the suspension while you're in there. Lots of options from sport shocks, all the way to adjustable coilovers w/ poly bushings (what I did.) Several very informative threads can be found by a search.
Another thing to consider is getting a road tested front-end alignment. Many members report that their factory settings were off by quite a bit. Steering adjustments and 4 corner balance also improve the handling, as do performance tires.
Just some additional things to consider.
Old Aug 4, 2008 | 02:03 PM
CraigE's Avatar
CraigE
I would also recommend the Pfadt Poly Bushings... only $30.
Old Aug 4, 2008 | 02:26 PM
AintQik's Avatar
AintQik
I did the Z51 swap on member Apex's car and he said it was a nice improvement. Pm him for a detailed description. I went from Z51 bars to Hotchkiss and love them.
Old Aug 4, 2008 | 02:52 PM
danl72's Avatar
danl72
I did the Z51 sway bars and PFADT poly bushing and it is well worth it. The handling is improved as well as the cornering. I would recommend it.
Old Aug 4, 2008 | 03:31 PM
A-Pex's Avatar
A-Pex
Also, as AintQik mentioned, this was a huge improvement to my F55 suspension.
Bottom Lines:
Without the Z51 sways, the car "let go" or leaned/listed over 0.6Gs of lateral force.
With the Z51 sways, it just stays nice and flat in the corners.
Highly recommend this mod!
Old Aug 4, 2008 | 09:11 PM
TCKT B8's Avatar
TCKT B8
St. Jude Donor '09 & '11
I did the Z51 swaybars with Koni FSDs on my base 05. Worth every penny and a lot more.
Old Aug 4, 2008 | 09:15 PM
edv2122's Avatar
edv2122
Did the same and added Bilstein Sport shocks. Nice improvement over stock. I got great deals on both in the parts section which made it even better.
Old Aug 4, 2008 | 09:24 PM
nwc6's Avatar
nwc6
The stock front bushings were already cracking/deforming around where the bar goes through the bushing.
The rear set were as new, but the fronts were definitely showing wear..This is an 08 with 3500 miles on it...
Old Aug 4, 2008 | 09:30 PM
csun213's Avatar
csun213
Where do you purchase them?
Old Aug 4, 2008 | 10:24 PM
Gene Culley's Avatar
Gene Culley
Premium Supporting Vendor
Most purchase the sway bars from me and then the Pfadt bushings from Pfadt Racing.
||--Z51 Sway Bar Kit--||
10323434 – Front stabilizer bar
10339124 – Rear stabilizer bar
10387838 (2) – Front stabilizer insulators
15241135 (2) – Rear stabilizer insulators
Complete kit front and rear is 183.00
For the Z51 bars on our website, use part number c6z51bars on our website under Chevrolet make.
Old Aug 6, 2008 | 08:56 AM
C746490's Avatar
C746490
Default Z51 sways and F55
What if any problems or benifits are there to adding Z51 sway bars to a F55 equipped 08 vert?
Old Aug 6, 2008 | 09:28 AM
danl72's Avatar
danl72
No problems. You will get better handling and cornering. The C6 won't lean when you turn hard.
Old Aug 6, 2008 | 10:24 AM
NewTxOwner's Avatar
NewTxOwner
Cruising
Default Does it affect ride comfort?
Will the change to the Z51 sway bars result in a rougher ride?
Old Aug 6, 2008 | 11:07 AM
CMY SIX's Avatar
CMY SIX
No!
Old Aug 6, 2008 | 11:36 AM
Nightstalker Medic's Avatar
Nightstalker Medic
I put Z06 Sways on my F55 and man can you snap turn the car.
I have no cornering issues at all. No body lean at all. Love the fact that I can switch to a touring ride and then back to sport for a stiffer ride when wanting one.
You should get the same results.
Old Aug 6, 2008 | 02:24 PM
danl72's Avatar
danl72
To z51 sway bars
Old Aug 17, 2008 | 12:43 PM
Radioman's Avatar
Radioman
I have the Z51 bars and Pfadt bushings ready for install on my 07 Base Coupe.
Will the OEM bushing brackets hold the Pfadt bushing?
Old Aug 17, 2008 | 02:16 PM
Modshack's Avatar
Modshack
Yes...They have the same outside dimensions..
Old Aug 17, 2008 | 02:25 PM
CraigE's Avatar
CraigE
Try this:
http://www.pfadtracing.com/catalog/p...products_id/55
