Which Cometic gaskets for LS3?
Old Aug 11, 2008 | 07:46 PM
71CamaroLS1's Avatar
71CamaroLS1
Default Which Cometic gaskets for LS3?
Just bought an LS3 crate motor to replace my blown-up LS1. I'm going to cam it, and want to bump the compression as much as I can with thinner head gaskets. Anybody got a recommendation as to Cometic part numbers? Anyone know what the piston-to-deck measurement is on an LS3?
Thanks for any help ...
Old Aug 11, 2008 | 11:40 PM
Trevor @ Texas Speed's Avatar
Premium Supporting Vendor
We stock the Cometic head gaskets for the LS3 engines in a 4.085" bore size, and they are currently on sale for $139.99 + shipping. We typically use a .045" thickness gasket, but other thicknesses are available. The .045" thickness gasket would give you a comfortable safety margin and net an optimal quench of ~.038" assuming that the piston is .007" out.
Feel free to give us a call with any questions or concerns.
Trevor
Texas Speed & Performance
www.texas-speed.com
806.866.0734
Old Aug 12, 2008 | 07:50 AM
Gotcha's Avatar
Gotcha
I used Cometic # SDL408540 4.085 bore/.040 thk
Raised compression to 11:1 (from 10.7:1)
Old Aug 12, 2008 | 09:21 AM
71CamaroLS1
Thanks for the answers!
Old Sep 15, 2013 | 10:15 PM
CSexy06VY's Avatar
CSexy06VY
Trevor
www.texas-speed.com
806.866.0734
what is the best gasket set for a ls2 stock bottom end with ls3 unmilled stock heads? what would the comp ratio be?
To Which Cometic gaskets for LS3?
