Im sure there is something on the forum but I am unable to locate exactly what Im looking for. I was wondering what is all needed to upgrade from base brakes to the Z06 brakes. I have rotors, calipers, and pads.
I am for sure going to but steel braded on her. Wanted to make sure I didnt need any brackets or any hardware that isnt already on the car. As for fluid I have no clue havnt done research on that yet. What should I use?
There are quite a few to choose from. I like Motul RBF 600, but for a DD, like mine, it may be over kill. There is a lot of talk about the different fluids in this section - http://forums.corvetteforum.com/auto...roadracing-23/ Good luck with your mods!
Another question, as for the bolts that hold the caliper to the spindle, do I need to get different bolts or should the ones that are currently on the car work. Thanks
I would PM http://forums.corvetteforum.com/memb...1-joe-zip.html They have a kit http://www.zip-corvette.com/ProductDetails/Kits/KitDetails.aspx?KitItemID={d2fc3060-727f-42fe-b1c0-ad0fb3fadd01}&gid={c351ca0f-8d5e-4c34-aea0-3a515531dbf6}&GroupName=Brake+Upgrade+Pa ckages&pname=97-13+C6+Z06+Brake+Caliper+%26+Rotor+Kit&Re ferer=&Alias=&ptct=SGR-SR&CTitle=& so maybe he my know your answer. Good Luck.
OP: Check this out from their website - http://www.zip-corvette.com/ProductDetails/Kits/KitDetails.aspx?KitItemID={d2fc3060-727f-42fe-b1c0-ad0fb3fadd01}&gid={c351ca0f-8d5e-4c34-aea0-3a515531dbf6}&GroupName=Brake+Upgrade+Pa ckages&pname=97-13+C6+Z06+Brake+Caliper+%26+Rotor+Kit&Re ferer=&Alias=&ptct=SGR-SR&CTitle=& 10th item down (05-13 Brake Caliper Mount Bolt
